Results 1 to 4 of 4
Thread: haveing problems with trick flow intake
    I am in the process of putting my motor together but I set the lower intake onto the block there is a 3/8 gap from bottom of intake to engine block . Has anyone seen this or what's wrong thannks
    Sep 2007
    Dayton PA
    3,795
    did you have your heads milled down or anything?
    03 Torch Red Anni. Ed. Cobra
    01 cobra: traded
    93 LX Modular 4v swap
    Sep 2007
    Homestead
    780
    Either the heads or the intake have been milled. Is the intake used ?
    Mikeymustang had the same problem with his trickflow intake way back when. Just put a LARGE bead of "the right stuff" (the black RTV stuff at autozone), and set the intake straight down on it ensuring you don't move the bead around and you should be good.
  1. trick flow intake
    By matty g in forum Ford Vehicles
    Last Post: 04-30-2012, 11:24 PM
  2. Trick Flow kit Problems HELP
    By scottyko88 in forum Fox-SN95
    Last Post: 07-18-2008, 11:10 PM
  3. Trick Flow intake
    Last Post: 05-09-2008, 08:01 PM
  4. Trick flow intake
    By scottyko88 in forum Pictures & Videos
    Last Post: 03-14-2008, 02:48 PM
  5. trick flow r intake
    By urgonnaluz2me in forum Ford Vehicles
    Last Post: 03-27-2007, 08:28 PM
