Results 1 to 5 of 5
Thread: Which speedo gear??
    Senior Member Dan B.'s Avatar
    Armagh, PA
    4,331
    Which speedo gear??
    I swapped from airplane gears to 3.55's in my 8.8". Which gear do I need to correct the speedo error?
    Ahh fuque
    1986 Ranger--2WD, 5.0/T5/8.8.
    Petersburg,PA. 16669
    816
    prolly just one more tooth than what you have. I'd say 19 or 20 tooth
    88 GT...and some boost
    Shaler
    1,224
    When I did 3.55's in my car, I had to use a White 23 tooth speedo gear, that's with a T5 trans, it may be different with an AOD.
    Dan
    95 Rio Red Cobra Coupe
    Armagh, PA
    4,331
    It must be different. I took the gear from the T5 that was in the Turbo Couple the 3.55 rear came from and it's off by 15mph.
    Ahh fuque
    I found a calculator that said 21 tooth.
  1. 20 tooth speedo gear
    By Dan B. in forum Ford Parts
    Last Post: 06-15-2012, 09:03 AM
  2. speedo gear
    Last Post: 01-26-2009, 10:14 PM
  3. Speedo Gear?
    By Stangman701 in forum General Tech
    Last Post: 10-06-2008, 11:21 PM
  4. Low Gear AOD...speedo now off
    By Chris00GT in forum Fox-SN95
    Last Post: 10-11-2007, 12:54 AM
  5. Speedo Gear
    By static-x in forum General Tech
    Last Post: 05-30-2007, 01:09 PM
