Thread: Tire Help (17" Bullet)
    Stocker Chevrolet Subaru mr4teth's Avatar
    Aug 2008
    State College PA
    2,326
    I mounted the G-friend wheels today and noticed she's going to need new front rubber. Currently she has 235/40/17 on the front, which IMO look WAY too small, and 275/40/17's on the rear.
    So what tire combo do you new edge guys run?
    2007 GT500 with a few go fast parts
    PICS & Dyno
    ...... GT500 is the most over-rated car ever made
    245's will also look too small if those are aftermarket 17x9 fronts which they appear to be. I assume those are 17x10.5 in the rear and 17x9 front, if so the ideal tires would be 315-35-17 in the rear and 275-40-17 up front. Since she already has 275's out back, you'll need a 255 or 265 is you can find them with the correct aspect ratios to match the rear tire height for it to look right.
    Aug 2008
    State College PA
    2,326
    Quote Originally Posted by Killercanary View Post
    Paul you think I should mount her rears on the front and get a set of 315's?
    PICS & Dyno
    That's actually a great idea. I'm 99% sure there will not be fitment issues in doing so as 315/275 seems to be the staple of modern staggered fitments on all mustangs '04-94, but let one of the guys with a 99-up car chime in. On the 94-98's a 17X9 can cause some rubbing with a 275 if the backspacing gets too close to 6". Stay just under it and they seem to work fine. I had to install '03 cobra A arms on my '94 after sending one of my '03 anniversary cobra wheels into the A arm during a slide since they are shaped different and allow for more clearance where mine hit. I have also since added rack limiters just to be on the safe side. I don't believe either of these are needed with a '99-up car, and honestly if I didn't autocross my car and really push the suspension I don't think I would have ever had an issue either.
    Aug 2008
    State College PA
    2,326
    OK I just found a SCREAMING deal on Kelly Fierce 255/40/17 (summer tire which is fine) ... Anyone have any idea how these may look with the 275/40/17 on the rear?
    315's are too much money and that lil 6 banger would probably have a hard time rolling them!
    PICS & Dyno
    GREEN=FAST sweeney1030's Avatar
    johnstown
    570
    i run 315/35/17 rears on 10.5 rims and 225/45/17 or 245/45/17 on the front with 8 inch stock bullitts the 245s rub a bit on the front because its lowered and c/c plated but does no damage.
    Senior Member Dan B.'s Avatar
    Armagh, PA
    4,331
    Quote Originally Posted by mr4teth View Post
    I mounted the G-friend.......
    Ahh fuque
    1986 Ranger--2WD, 5.0/T5/8.8.
  1. 2005 tire size 18"
    By Hankwedge in forum S197
    Last Post: 07-10-2013, 01:00 PM
  2. WTB: 27" or 26" x 10.5 x 15 Bias Tire - M/T, MH, Hoosier
    By somethingclever in forum Ford Parts
    Last Post: 10-13-2011, 08:40 AM
  3. M/T ET Streets DOT 16" 28X12.5 true 10" tire
    By Dave King in forum Ford Vehicles
    Last Post: 03-15-2009, 10:12 PM
  4. Should I go to 3:90's or 4:10's with 28" tire
    Last Post: 01-03-2009, 02:16 PM
  5. M/T ET Streets DOT 16" 28X12.5 true 10" tire
    Last Post: 05-11-2007, 12:44 PM
