Results 1 to 4 of 4
Thread: 4:10's
    May 2009
    Leetsdale
    226
    4:10's
    Mike,
    Im ready to have my 4:10's installed in the near future. I will have everything ready. I need to know how much gear lube is required for the install. and what weight. I will get royal purple. I will call you at the shop when I have everthing.
    thanks-
    Andy
    4,321
    Quote Originally Posted by 40thGT View Post
    Mike,
    thanks-
    Andy
    Ford calls for 75W-140, just get 2 quarts. If you need anymore, I have some here at the shop I can top you off with. You also need 1 bottle of friction modifier, I have those here at the shop as well. Royal purple states that have it pre mixed in their lube but I put a bottle in anyways. Don't get an install kit, I prefer to use mine when possible.
    The list is long and growing so I would call asap so that I can get your info and put you down.
    Thanks in advance for your patients!
    Mike
    May 2009
    Leetsdale
    226
    thanks mike..ill be giving you a call by the end of the month
    4,321
    Sounds good, thanks!
