Results 1 to 16 of 16
Thread: need help here pls ford guys
    whatever it takes stangfever's Avatar
    i b where im at
    674
    i have a 98 f150 with a 4.6 auto that has a serious miss at low rpm's while driving not at idleing . i replaced injectors, plugs, wires, and even swapped the coils out and it did not change anything .. it threw the engine light b4 and it came up cyl 4 misfire and thus being the reason i tried changeing stuff .but it is not throwing the light anymore and i dont know or have any other ideas .its not a constant miss it comes and goes so any ideas or input would be apprecheiated . thanks
    TODAY IS THE DAY I MAKE A DIFFERENCE !!!!!
    o2 sensor?
    How does the plug in that cylinder look?
    Senior Member RAYZ02GT&93LX's Avatar
    Oct 2008
    Eighty Four
    215
    If you replaced your plugs wires and coils. You could have fuel, evaporative emission, or base engine concern. Check to see if the engine has a dampner mounted pulse ring. You want to check the crank pulley for wobble and inspect the pulse ring sometimes its necessary to remove the front cover. If the dampner wobbles you need a new dampner
    i b where im at
    674
    Where is this pulse ring ??
    o2 sensor?
    x2..How long do you usually drive it? If you don't drive it for a long period of time, the computer doesnt go through all the checks it needs to provide a check engine light if it needs to. So say you drive 2 miles a day, it probably doesnt go through the whole system, just as far as you drive it. Take it for a long drive probably 35-40 minutes, if a check engine light comes on get it scanned right away. If not, well..Not really sure..but I was thinking 02 sensor as well. Hope you get it fixed!
    Matt
    94 Ford Ranger
    01 KX125
    2002 Ford Mustang GT - 13.96 @ 98.8 (sold)
    try cleaning the MAF
    Quote Originally Posted by RAYZ02GT&93LX View Post
    Quote Originally Posted by stangfever View Post
    see above
    Coil and plug. Mine eats one about every six weeks.
    member
    Aug 2008
    north hills
    21
    Mine does this frequently after heavy rain. Moisture gets around the plug boot and down in the head. I have to pull the boot and dry out the hole and that fixes it.
    out in the woods
    4,948
    if the dampner is bad he would feel a vibration..
    2003 polaris predator 500
    (wanna ride,just pm me!!!)
    Oct 2008
    Eighty Four
    215
    Quote Originally Posted by INSANELY CRAZY View Post
    It can but not always.
    SexyManBeast KeystoneJohnny's Avatar
    Irwin
    888
    My guess would be something with the coil as well. I've experienced some of these same issues before and moisture around the c.o.p. and or the c.o.p. itself can cause these issues. Good luck hope you find the problem.
    Life is a Journey, enjoy each moment. Don't take life to seriously, none of us make it out alive anyway.
    Toys:
    1993 Cobra #1118 Black/Black Cloth 45k
    2013 Ford F-150 FX4 4x4 C.C.
    1997 SeaRay 190RS MERC. S.S. prop./Hydrafoil
    2005 Honda Aquatrax R-12x & F-12x Turbo's
    2010 Kawasaki Z1000
    2005 Ford Mustang GT/Roush Stage1 Package **FOR SALE ASAP**
    Quote Originally Posted by pRojekt02GT View Post
    Agreed. Only reason I suggested it was because ive seen misfire codes come up when an O2 was bad......Damn fords!
    i b where im at
    674
    02 would throw a light and i have no light and yes it feels exactly like there is water in the head .ive had that happen b4 . feels exactly like that but not all the time . im thinking maybe a fuel regulator cause it breaks up on heavy pulling or when i get on it pulling out .. but i hate to keep to guessing its expensive that way .. so thanks guys and keep the ideas coming
    and i dont think i have a map sensor and i have the 4.6 with just 2 coils not 8 if it makes a difference
    most of the time a miss when under load is an ignition problem though. Usually......
  1. Replies: 67
    Last Post: 07-05-2013, 04:16 PM
  2. Ford F-150 guys need advice
    By 89stang in forum Other Ford
    Last Post: 04-18-2013, 03:08 AM
  3. info needed here pls ford guys
    By stangfever in forum The Bar
    Last Post: 11-10-2011, 09:59 PM
  4. New Ford Racing Mustang Powered By Ford Valve covers
    Last Post: 05-05-2011, 11:52 AM
  5. chevy guy in here pls
    Last Post: 09-23-2009, 08:00 PM
