Page 2 of 2 FirstFirst 12
Results 21 to 28 of 28
Thread: New Daily Driver
  1. #21
    Jan 2008
    Jefferson
    4,674
    Quote Originally Posted by ArmyWarrant View Post
    ABS, ASR, AIR BAG, BRAKE PAD WEAR SENSOR AND CEL.
    The CEL light is the upstream O2 Sensor and I have to retp my down pipe or order a new one, the old sensor messed up the threads and I was lucky enough that it went back in so I can drive it.
    just change the brake pads with a new sensor and that will go off. did you try pushing the ASR button to turn that off?? what codes to you have?? a regular scanner will read that.
  2. #22
    Fort Eustis, VA
    525
    I put new pads on it but, when I first got the car the PO had drove the car for a while with a bad wheel bearing and the brakes failed on him andhe hit a curb which is what broke the wheel. Also while he was driving it with the bad bearing it cut the harness for the wheel speed sensor and the brake pad wear sensor.
    I soldered in new wires but I think I need to replace the harness and the wheel speed sensor and then I will put new pads on it again.
    The only codes I got when I scanned it was for the O2 sensor.
    I have tried pushin the ASR button and it don't do anything.
    I also discovered today that the hatch won't open and since I don't have anything but a valet key for the car you have to use the button inside the car to open it. I can feel it seem to pop the latch but it still won't open, IDK what's going on there
    86 Notch New Project
  3. #23
    Fort Eustis, VA
    525
    Got some pics today, not the best didn't have my tripod so was holding the camera
  4. #24
    Fort Eustis, VA
    525
    Well its back to having the Konig hotswaps on it. I also fixed all the lights, put a new harness in for the left front abs/brake pad wear sensor sensors, and that also fixed the ASR light. The airbag light was on because the stealership didn't reset it when they put the new cluster in
    I am also going back to stock with the intercooler, the FMIC is just to big for my taste.
  5. #25
    Senior Member ttk53's Avatar
    Sep 2008
    369
    just throw some black paint on that front mount, hide it a little
  6. #26
    Fort Eustis, VA
    525
    I might do that, but it also hangs a lil lower than I like, I am wanting to lower the car a lil especially in the back and I really can't with the front mount on it. IDK I already bought the stock intercooler stuff. I might see if I can remount it and get it some more clearance.
  7. #27
    Car looks nice!
    How can that intercooler survive exposed out front like that?
  8. #28
    Fort Eustis, VA
    525
    The bottom is banged up a lil, which is why I want to try and go back to stock, I think the only way to get it raised enough into the bumper is to cut the metal reinforcement and notch it for the intercooler. I might look at it this weekend to see what I can do about it.
  1. my new daily driver
    Last Post: 04-03-2011, 04:57 PM
  2. My new daily driver
    By Rio94gt in forum Pictures & Videos
    Last Post: 04-19-2010, 02:52 AM
  3. New Daily Driver
    By Stangman701 in forum The Bar
    Last Post: 02-02-2009, 05:43 PM
  4. My new daily driver.
    By lib88stang in forum Pictures & Videos
    Last Post: 04-01-2008, 01:01 AM
  5. looking for a daily driver - what do you have?
    By PaxtonShelby in forum Ford Parts
    Last Post: 02-10-2008, 12:45 AM
