Results 1 to 11 of 11
Thread: FLYWHEEL RUBBING BLOCK PLATE? Whats it mean?
    Mustang Guru billyNOTnice's Avatar
    Huntingdon PA
    1,136
    Question FLYWHEEL RUBBING BLOCK PLATE? Whats it mean?
    My flywheel keeps rubbing my block plates. Initially i thought my blockplate got bent when i tore the old motor down. But i put a nice new custom block plate in there, and i just had to replace my clutch, and now it's rubbed up too... i'm not sure if it's the 28oz flywheel rubbing this thing up or what. I have a FMS flywheel. The new blockplate is bowed now too a little bit. What could be the cause of this? This is a basically new motor. Thanks for the help.
    Roll With The Mill Creek Mafia
    709RWHP/750RWTQ
    Under PSI Black Vert's Avatar
    Cranberry Twp.
    344
    Check your crankshaft end play, maybe somethings up with your crankshaft thrust bearing?
    89 Vert, Stock block, H/C/I , DIY turbo kit MPT70 , Tweecer RT, C4 trans. 17 lbs boost. 3400#s - 10.3 @ 136 mph.
    Dyno Jet - 542 RWHP / 545 RWTQ
    pics of where it's rubbing?
    Huntingdon PA
    1,136
    Re: FLYWHEEL RUBBING BLOCK PLATE? Whats it mean?
    its rubbing directly north of the crank an inch or 2 ill get a pic
    Sent from my Droid using Tapatalk
    709RWHP/750RWTQ
    Huntingdon PA
    1,136
    here's the pic, as you can see on the one it's beat up from me trying to flatten it back out which failed miserably... but here's the pic.
    709RWHP/750RWTQ
    Put a dial indicator on the crank flange and see if it's bent.
    Check crank end play as already noted.
    Do you have to force or load the block plate at all to get bolt holes to line up, maybe causing the plate to slightly bow outward?
    How much clearance is there between the plate and back of the flywheel if you were to bolt the plate to the back of the block.
    (I'm grasping here but this seems like an odd issue)
    Any vibrations? Positive the flywheel is flush on the crank? Is it a constant scrape or like a chattering scrape?
    Cranberry Twp.
    344
    If its only rubbing on one side the plate is bowing when you install the trans. Try bending it back straight then grind or drill the bolt and dowl holes a little bigger. If it still rubs after trans is installed try to pry on the plate in different areas until it quits rubbing. I've had this happen a few times on different vehicles and prying on it usually works.
    Huntingdon PA
    1,136
    sorry guys, just got home from the bahamas. I'll update soon
    709RWHP/750RWTQ
    Senior Member blizzard's Avatar
    Mar 2008
    Castle Shannon
    1,276
    i have a couple plates like this, seriously i think it just gets bowed. but how thick is that fab piece? i pre-bent my latest one so it flattens out toward the block when the trans goes up... meh, my 2¢ :P
    Huntingdon PA
    1,136
    it's not very thick. I didn't have this problem until i got the 28oz flywheel and motor combo. Not sure if it's the flywheel causing it or what. I Might just cut the circle out bigger out of the way of where it's rubbing and say to hell with it.
    709RWHP/750RWTQ
  1. 324 Boss Block Big Bore Stroker short block $2,900 O.B.O.
    By Stroked03Cobra in forum Ford Vehicles
    Last Post: 05-03-2014, 03:19 AM
  2. Biggest size tire without rubbing 20"
    By Hankwedge in forum S197
    Last Post: 07-01-2013, 04:31 PM
  3. shorty header install rubbing
    By Darren in forum S197
    Last Post: 09-09-2012, 10:22 AM
  4. Replies: 2
    Last Post: 12-04-2011, 11:09 AM
  5. Steering Shaft Rubbing LT Header
    By 02pnygt in forum SN95-New Edge
    Last Post: 05-19-2009, 07:31 PM
Tags for this Thread
