Thread: Stang wont start
    Senior Member ruger77's Avatar
    Mar 2009
    Greensboro, PA
    133
    Stang wont start
    I forgot to shut off my sirrius radio in the car 2 days ago and it killed the battery. Chargerd the battery, now the car wont start. I got spark, starter is engaging but no fuel. I checked emergecy fuel shut off, OK. I pulled the fuel relay and jumpered the connection, fuel pump energized. Went and got new relay still wont start. Any help?????????? Its a 88 5.0 GT.
    • 1988 Mustang GT - 5spd. - 12.09@117 Procharger just added! Times???
    • 2005 Dodge Ram Hemi - 13.57@ 100.9mph(75shot)
    • 2006 Eclipse GT - 6spd. - wife's - 14.09@ 97.9mph (CAI only)
    • 2010 Focus SES - wife's - 37.8mpg!
    so the pump works? Is there fuel at the rails? Try an easy part like the filter first and work your way up to the injectors.
    Mar 2009
    Greensboro, PA
    133
    The pump kicks on when I jump out the relay connector. But when I put the new relay on and try the key the pump will not work!
    Maybe the ignition switch went bad? I had a neutral safety go bad while my car was down a few days. The fuel pump kicks when its jumpered, but nothing when the key is on the "run" position. I believe its also cut off when the key is in the "start" position. Could try jumpering the hot lead from the ignition switch directly to the relay feed. I believe its the large diameter yellow wire coming out of the ignition harness.
    Mar 2009
    Greensboro, PA
    133
    I will give it a try. Thanks
    I started a thread in another forum for a similar problem. I pulled the interior out to put new floors in my 86 GT and after reinstalling, I can't get the fuel pump to work. I'm new to the Fox thing. All this electronics, relays and EFI stuff is a little different than the good ole carbureted stuff.
    '66 Sunbeam Tiger
    Mar 2009
    Greensboro, PA
    133
    Couldnt get it fixed so it went to the garage and the relay for the ECU was bad. $14 part!
  1. car wont start
    Last Post: 05-09-2012, 05:57 PM
  2. F150 wont start...
    By 92306gt in forum General Tech
    Last Post: 12-04-2010, 10:12 PM
  3. Another start to a project to the stang
    By wick in forum General Tech
    Last Post: 04-27-2008, 12:17 PM
  4. Mustang wont start
    By 2001GTTT in forum S197
    Last Post: 12-09-2007, 04:56 PM
  5. car wont start
    By yeahloh95 in forum Fox-SN95
    Last Post: 09-21-2006, 07:26 PM
