Page 2 of 2 FirstFirst 12
Results 21 to 39 of 39
Thread: exhaust popping
  1. #21
    Your mom cwh19's Avatar
    May 2009
    Greensburg
    1,383
    Quote Originally Posted by 89 vert View Post
    Update: Found left side 02 sensor with 1 wire broken off. I re connected the wire and it made no difference. I sprayed everywhere there is vac. and intake with spray, and no idle change at all. It is getting a little worse. It will do it it now here and there at idle. Sometime it is a loud backfire when I start it. This weekend I will be trying to get the codes out of it. Should the 6al box be making a ticking sound when you put your ear near it??
    Maybe the broken wire killed the O2. Try a new one.
    Did you pull the plugs?
    15gt
    94gt
  2. #22
    plum
    487
    I will be installing new o2 sensors tommoro, the plugs are a little rough to get out because of longtubes, but I will try that tommorow also, thanks
  3. #23
    If there are no codes then its going to be something simple. Have you tried a coil yet? Checked all grounds? My ground issue I had last year did something similar to what you are having now. When my fan came on it triggered the injectors and everything. Does this happen with the car hot or cold or both? How long after you start the car does it take to happen?
  4. #24
    plum
    487
    Whats up Rob,, It does it instantly when started, all the way till I shut it off. I am going to eliminate the msd box and try that. I will be checking all the harnesses and grounds thoroughly tommorow. I might throw a new coil in it if this does not work.
  5. #25
    Does your fan come on with the key or a sensor?
  6. #26
    Sorry to hear the vert is still giving you fits Jason. On the vacuum lines - did you pull them off and check them closely? They might look fine at first glance, but if you bend them backwards you might find they're dry-rotted and split. Happened to my '87GT convertible and Dad's '57 TBird years ago. Good luck chasing this one down. Keep us posted!
  7. #27
    plum
    487
    I have a switch on the inside. On or off it still misses
  8. #28
    plum
    487
    They are all new within the last year, but that doesnt mean they are ok. i am planning to pull the upper to get a better look at everything tommorow, thanks Ron
  9. #29
    Petersburg,PA. 16669
    816
    put a coil on it and try that
    what wires are on the car?
    88 GT...and some boost
  10. #30
    plum
    487
    As of today I put stock motorcraft wires on it (took off the taylor 9mm wires) cleanned the salt and pepper connectors, took out the baro sensor and cleanned it and sprayed 3 cans of brake clean on every single hose, gasket and intake. Not sure if this means anything, but i can rev it up in neutral with no stumble, it idles great and wot is perfect no matter what rpm or gear im in, once I back off the throttle from wot, it stumbles like a missfire, or 7 cylinders. Coil was ordered today from summit as well as 02 sensors. Am going to spend the rest of the nite checking and re-doing all the grounds. Let me also add this little bit of info, Right after it started stumbling on the turnpike, we started smelling a terrible smell of rotten eggs. When we got to the hotel, I opened the trunk and smoke poured out from the battery box! My red top battery fried itself and acid ran all over. I purchaced a new battery at autozone and all was well. Not sure if this caused the problem or not but it seems funny that both things happened at the same time.
  11. #31
    May 2009
    Greensburg
    1,383
    Do You have cats on the car?
    15gt
    94gt
  12. #32
    plum
    487
    No cats, I took it down and filled it up with gas and ran the hell out of it. Its great through the gears full throttle, but anything else is crap.
  13. #33
    Hey Jason, pull the computer out and call or text me after you open it up. You need a T10 and a 15 I think.
  14. #34
    plum
    487
    Update: pulled the computer and found a bad ground wire connection. While it was out I checked the board for any sign of failure and all was well. Re installed the computer and still ran like crap. re checked the tps and the voltage was .93 so I bumped it up to .98, and put a new coil on it, still runs like crap!! Sprayed a nother can of aresol on everything, with no luck.
  15. #35
    NEWB 89stang's Avatar
    North Huntingdon
    1,136
    Man that sucks. I know your pissed!
  16. #36
    Did you check the ground circuts like I told ya yeaterday? Pin 20, 40 and 60.
  17. #37
    plum
    487
    Ground circuits all check out exactly like you said. Spent the nite driving all over trying to find 02 sensors. I found them, installed them and no luck!! Next i'm pulling the headers to get to the rest of the plugs, and replacing them.
  18. #38
    plum
    487
    I THINK I GOT IT!!!!!!!!!!!!!!! The rear plug on the pass side was totally full of crud and corrision in the gap. I have never seen anything like it, there is no way spark could have been jumpin across it. The crust is so hard, I cant even clean it off. Ihope this is it! Ill pick up new plugs tommorow, can't wait!!!!
  19. #39
    4,321
    Jason,
    Good speaking with you today! I thought you said you already replaced the plugs? Either way, I wonder why that particular plug is so bad? I think I have a set of new plugs for your application at the shop. I live in Plum so let me know if you want them and they are yours! Good luck either way!
    Mike
  1. exhaust?
    Last Post: 03-21-2012, 08:01 PM
  2. new exhaust
    By Chris Coccari in forum General Tech
    Last Post: 12-02-2011, 10:31 AM
  3. exhaust help
    By 84QuadEye in forum Fox-SN95
    Last Post: 02-24-2011, 10:05 PM
  4. Gene Simmons popping in at the Hard Rock
    Last Post: 10-02-2009, 01:57 PM
  5. Miss and popping
    Last Post: 07-05-2008, 05:11 AM
