Cant seem to figure this one out. Half way to Carlisle the car started backfiring out of the exhaust while on the throttle. At wide open it goes away. It also has a miss to it while it is backfiring. The more gas I give it, the less it does it. It idles very steady and smooth. It runs great on full throttle. So far I cleaned the mass air twice, checked the wires for damage, checked all the clamps on the intake, cleaned the cap and rotor, adjusted timing, visually checked for vac leaks. I have a check engine light but it has been on for 4 years. It will do it no matter if its cold or warrmed up, consistantly. I also checked the barometeric sensor plug. Thanks for advice!!
