Results 1 to 20 of 22
Thread: Small bore 8.2 362", 4 link Ranger, yadda yadda
    Retard
    Apr 2009
    Hopewell - Pgh Airport
    73
    Seeing as how everyone loves bench racing, here goes:
    Doing a 3.550 x 4.030 362" 8.2 deck all motor job. TW-R, Super Vic, carb deal. .74x" solid roller, shaft rocker blah blah blah. Motor is alllllllllmost done, need a vac pump. Faceplated TKO & a fancy (for this honky) clutch. 7800-8200rpm oughta make some noise.
    Decided with the new motor to update the chassis to a 4 link, coil overs, etc. Thankfully got the ex the **** out of my house & I'm trying like hell to get this done before winter. Trying to pop that 9.99, we'll see.
    Pics:
    Looks good man!
    Very nice bro!
    Any pics of the truck?
    What kind of compression?
    Cant wait to see this beast running!
    Retard
    Apr 2009
    73
    Thanks Shaun.
    Rob, I had some pics of its previous configuration but I have no idea where they're at (pre-digital camera!). Long story short it is a 95, has sat for 3 years, and I needed to patch/replace a panel here & there. No paint on it yet. Compression is 12.3, I'm using E85 on this one.
    Sounds badass man! What block are you running?
    Keep the pics coming! I'd like to make it down your way to check it out!
    Retard
    Apr 2009
    73
    It's a (gulp) Mexican.
    Go or blow!
    Petersburg,PA. 16669
    816
    Quote Originally Posted by mxracer652 View Post
    Go or blow!
    it will go !
    88 GT...and some boost
    Go or blow!
    You'll be fine N/A but if you throw some juice I might get a little worried...lol
    Good luck bro!
    Retard
    Apr 2009
    73
    No smack on this one, I'm not going to chance it.
    I should have the 4 link finished this weekend. Need to get the 9" ends put on the rear & order axles.
    Member mlowry1260's Avatar
    Caledonia, Ontario
    620
    Looks like a nice build. What's the details on the heads & intake.
    I have some old pictures & video of a friends blower ranger that ran 9's It was a sweet little truck and looked very clean with a good stance.
    Mark Lowry
    Retard
    Apr 2009
    73
    Heads are the 206cc as cast TW-R versions from TEA, CNC chamber, bowl blend & Ferrea stainless valves. Super Vic is 100% out of the box. I do have a nice Pro Systems HP950 on top :)
    What did your buddy's truck 60ft and what was his suspension setup? That's my biggest problem.
    That super vic is going to need port matched to your heads as there openings are rather small. I sent mine to Duane Busch and he did an excellent job for a very reasonable price!
    What kinda raceweight are you looking for?
    What kind of fuel do you plan on running?
    Retard
    Apr 2009
    73
    Yep, I noticed that during mockup, and way back 2 years ago when discussing this build, I was told for this combo, for what it is, to just run the intake OOTB. Right or wrong, yay/nay, I'm going to leave it for now.
    Weight I'm expecting at 2900#, it went on quite a large diet during all of this, but I am adding in some more frame bracing, etc.
    Fuel is E85
    Caledonia, Ontario
    620
    Mikeys truck ran in the 9's and I want to say it had 1.4 60 foot times. It had a ladder bar rear suspension. If you send me your email in a pm I can send some videos.
    Lightning air pumps will work for a while as an vacuum pump. From what i've read the vanes in the pump are degraded by oil and they slowly lose suction. I believe GZ uses this same type of pump and installs a tougher oil resistant vane material. gmkiller is right about star pumps being the choice of the serious race crowd.
    Mark Lowry
    Retard
    Apr 2009
    73
    Put some time in this weekend.
    Lookin good bro!
    Keep the updates coming!
    Retard
    Apr 2009
    73
    Thanks gm. I'm on a time crunch to have wheels back on this thing by the 4th to get it out of the garage. We have an annual party & the way it's been raining, we'll probably need cover!
    robinson
    1,091
    looking good. let me know if you still the ends welded on. i have all the pucks here now for 8.8 carrier and the 9 inch housing ends.
    /twocents
    Retard
    Apr 2009
    73
    If you have a jig to weld the tubes up too, I'm in.
    Made a little progress tonight, shock mounts on.
    Retard
    Apr 2009
    73
    Need to put the panhard bar on & the suspension is done. Waiting for the axles n ends & junk to get the rearend finished. I think we have a winner.
  1. bore limit for 351 W
    By k7cobra in forum Fox-SN95
    Last Post: 04-30-2012, 09:58 PM
  2. standard bore size of a 98 4.6
    Last Post: 09-19-2011, 10:02 AM
  3. Stock bore 302 block
    Last Post: 03-10-2010, 07:28 PM
  4. FS: 93-97 Ford Ranger "blackout" Headlight Covers
    By RUSH2112 in forum Ford Vehicles
    Last Post: 08-14-2007, 06:22 PM
  5. New Kenne Bell Big Bore Blowers
    By mlowry1260 in forum SN95-New Edge
    Last Post: 09-15-2006, 05:14 PM
