Results 1 to 18 of 18
Thread: Got truck issue today.
    I took my truck to work today and this morning drove fine no issues at all, sat for 10hrs while i was working and when i went to leave started it up and sat there till the parking lot got cleared out and while i was sitting there is started to idle rough, but rpms stayed constant and did not bounce around and then leveled out again so i pulled out and started doing it again, engine running rough but no jump in rpms then would go away, Did this the whole way home. When i was close to home it did it again, but this time the check engine light started flashing and a loss of power came, but once i slowed down to stop the light went out and went back to smooth driving. Pulled it into my driveway and i havent started it since.
    This happen to anyone? Any place i should start checking? I was thinking maybe something to do with spark, but i dont smell fuel.. Coil pack?
    Thanks in advance
    Senior Member TJH64's Avatar
    Delmont PA
    320
    Flashing check engine light=misfire.
    Take it to advance auto and have them pull the code, and it will tell you which cylinder has the misfire, more than likely a coil pack.
    My '04 w/ 165,000 miles on it has done the exact same thing 4 or 5 times, and each time it was the coil pack.
    Good luck
    fairmont,WV
    1,352
    Did you have the pouring rain today? Sounds like one or more of the coil packs got wet. Look and see if your coil packs are dirty, if so clean them and see if it goes away.
    XXX RWHP
    XXX RWTQ
    out in the woods
    4,948
    coilpacks are a big issue with the fords, i know bunch of people that have had problems with them.
    I didn't check them yesterday cause it was raining, but yea it rained all day.. I did how ever go out last night after it sat for a few hours and started it up and it idle'd fine for about 15mins.. didn't drive it though and still sitting at home as I brought the bike today just incase.. going to try to get to advance before they close tonight..
    Will the reader still pick up the code even if the light only flashed for 30seconds and hasn't came back on since?
    Sep 2008
    555
    We had an 00 4.6 F150 that did that randomly. CEL would flash every now and then but couldn't pull any codes out of it with a scanner. The CEL never stayed on constant. I replaced the plugs and all the COPS and it's run fine for about 4 yrs now.
    Live free or die
    what does cop actually stand for?
    Sep 2008
    555
    Coil over plug. I still have the 8 old ones just in case.
    Live free or die
    That's what I thought, but wasn't completely sure.
    2,103
    My 2000 with the 5.4 did the same thing when I first got it. I replaced all the plugs and the coil packs with a set of accel ones. All has been well since then.
    03 Cobra=slow show car...
    13 F-150 Limited
    what the accel ones run you steve? ford wants 50 a piece for them. These the ones you got?
    http://www.summitracing.com/parts/ACC-140032-8/
    2,103
    That would be them! Yea there was no way I was gonna pay 50 a piece for them. Figured I would try these for half the price.
    13 F-150 Limited
    So far so good?? I don't like using aftermarket stuff on my dd but 400 bucks is just crazy
    2,103
    So far so good yes.Bout 20k miles on them.
    13 F-150 Limited
    Sep 2008
    555
    $75 for a set of 8:
    That's where I got them, back then they were more like $115.
    Live free or die
    Polar Vortex
    6,031
    Quote Originally Posted by scorpio333 View Post
    $75 for a set of 8:
    Damn....thats cheap.
    SexyManBeast KeystoneJohnny's Avatar
    Irwin
    888
    If you shop around scott, try google them for sale or type cheap, sometimes I've seen a few deals on them.
    Toys:
    2013 Ford F-150 FX4 4x4 C.C.
    2010 Kawasaki Z1000
  1. Electrical issue
    Last Post: 01-02-2009, 08:21 PM
  2. This truck killed two people on 70 today
    By John4cam in forum The Bar
    Last Post: 11-05-2008, 06:53 PM
  3. MMFF Issue Help
    By J-rod in forum The Bar
    Last Post: 03-04-2008, 09:27 PM
  4. brown truck brought the new wheels today
    By Cam99 in forum Pictures & Videos
    Last Post: 10-18-2007, 12:54 AM
  5. Couple new pieces the brown truck brought today
    Last Post: 09-08-2007, 02:17 AM
