I have everything you need to change a 4 cylinder automatic over to a 5-speed I out of a 91 lx. The clutch and pressure plate are about two years old and I had the flywheel was resurfaced at that time the transmission shifted great. The clutch was doing fine.
The transmission will have the harness for the back up lights and the pedals will have the safety neutral switch.
double hump cross member
If you want to change the hump in the floor board that will be $25 extra.
I'm not much on Im's or email just call 304-478-4430 Lee
Best time to call is 8:00 to !0:00 pm And if you don't get to talk to me call back I will not receive any message that you leave.
To locate me use map quest zip 26287 Parsons WV
