wick if that was ur red car last night, that thing sounds f'in nasty
when i seen u rolling up line i heard it ,i acted like a little school girl just to here it
nice ride
nice ride
Mustang 00 v6- Mini Termi
Mustang 94 v6-sold
Mustang 93-sold
Mustang 86 notch 2.3-sold
Thanks Rick!!
Thanks man. I just need to learn how to drive it now.
My next time out it will do an 11.?? pass. I can assure you that. How deep into the 11's is unknown. Mind you, the car is not set up at all for drag racing. Once I do the rear arms and set that all up it will go tens for sure.
wick let me take down the 1320 this week :)
The car has the power for 10's the way it is now, everything else just has to be working with it and you can get in there. What gear are you running and what RPM did you cross the finish line at?
I went 10.80 with that motor on a 150 hit
The gear is a 3.73. I was crossing on the limiter. It was at 7000+ I have not set it yet where it should be and I was hitting it way early. Seemed like I was on it for ever. HAHA I would have to guess probably 200' or more short of the traps. I have a couple sets of tires lined up to try. Its basically which ever fit is whats going to be on for thursday providing I get my t boxes done. One set is 26x9, another is 27-10.50 amd 28-10.50. The 28 will be ideal to give me the run I need and take the gear away. I want to pull all the way to the end. I really dont want to be on or near the limiter at any point. Its just too high for the stock block.
I run a 3.31 gear and a 275/50/15 tire, going thru the traps at 6000 rpm. What kinda power adder do you have?
A taller tire, good 60' and keep off the rev limiter, should be 10s no problem.
what do you need? i have 2 sets metco alum and maximums let me know
Was hoping to go tomorrow and see Rob run a better tire, but they added a work dinner I have to go to :(
Maybe next time.
BTW, I will be doing some testing at a Milan track rental next Friday, wish me luck :)
Car sounds wicked at 19psi, I will post a vid later.
I hope it doesn't rain, I'll be there. This car hits hard now with the new converter.
