Results 1 to 11 of 11
Thread: My latest upgrades to the turbo Focus
    it's soo-tack sutyak's Avatar
    Fairmont, WV
    2,467
    Thumbs up My latest upgrades to the turbo Focus
    Here is my original build thread: sporadic's Turbo Duratec build thread from July 2007
    I can't believe it's been that long!!
    - Upgraded IHI turbo: fitted with 440 CFM compressor wheel vs. 350 CFM. Mild turbine outlet porting.
    - 3" blow-through MAF instead of stock MAF + MAFia draw-through
    - New ambient pipe and filter location
    - Relocated coolant expansion tank to driver's side using Mini Cooper expansion tank.
    - Solid passenger mount with poly bushings
    - Ford Racing suspension with poly rear control arm bushings and LineX'd control arms
    - Completely new tune with help from Tom, fine-tuning and tweaking by me. (big kudos for Tom)
    I'm extremely happy with these latest and possibly final upgrades.
    I wanted to relocate my ambient pipe because it was running under the engine and hung too low for my taste.
    The ideal option was to position the air filter on the passenger side, where the coolant expansion tank was located.
    My solution was to move the expansion tank, but finding one small enough was difficult.
    I found a Mini Cooper tank was perfect, but I needed to drill a second coolant return since it only had one.
    The Ford Racing suspension kit was what this project started out as.
    I ran into a control arm bolt rusted to the bushing sleeve and opted to upgrade to Prothane bushings instead of buying a new OEM control arm.
    While I had the downtime waiting on bushings to arrive (long story, eventually bought the whole entire kit from CFM) I sent my turbo off to be fitted with a 440 CFM compressor wheel.
    The IHI RHB52 is a tiny turbo and choked after 5300 RPM.
    With the upgrade it now makes power to 6500 RPM with little to no difference in spool time. [woot]
    It doesn't just mean more peak power, but it means it's making power longer without falling off so quickly.
    While waiting on the turbo to come back I ordered the coolant expansion tank, and also took a spare set of control arms, beat out the old bushings, and took them to my buddy to be coated in Line-X.
    I also ordered a new BOV and a 3"-to-2.75" 90* silicone bend for my new 3" MAF pipe. The 2.75" is for the throttle body.
    There is a 2.5" 90* bend to a 2.5"-3" adapter for the 3" MAF pipe.
    I can't recommend this configuration to anyone, as it turned into an annoyance with tuning, but I did get it figured out for now.
    See the Tuning sub-forum for that thread.
    The FRPP suspension is great.
    The drop was ~1.5" in the front and 2" in the rear.
    It took a solid week of driving for it to settle down to that height.
    It felt squishy at first and I was a bit disappointed, but there is a world of difference after a week.
    The difference going from a bypass valve to the BOV took some getting used to.
    My car was a sleeper, but now turns heads.
    After a few years as a sleeper I don't really mind a bit of attention.
    Before even on the dyno nobody realized my car was turbocharged!
    I'll post a video of the new sound sometime soon.
    The solid motor mount was something I made probably a year ago.
    The vibrations were outrageous.
    I bought some urethane sway bar end-link bushings and that helped for sure.
    The vibration is still significant, so it's not an upgrade for the faint of heart.
    There are currently little pieces of paper/napkins wedged in the air vents to control rattling. [hihi]
    So at this moment everything is back together with no leaks, tuned, and running better than ever.
    I hope to get to the track this summer/fall and also back to the dyno.
    Engine:
    Engine before:
    Solid mount installed:
    Solid mount before paint:
    Ambient pipe:
    Coolant tank (MAFia is now gone):
    Old compressor wheel vs. new:
    New compressor wheel:
    Line-X'd control arm with poly bushings:
    BOV location and 3" MAF pipe:
    FRPP suspension:
    Before (you can barely see the old ambient pipe under the car):
    Nice upgrade Mark ...
    What did you do for your blow through MAF, is that a slot sensor or housing unit? Either way, with the bends and transitions, some flow straighteners will likely help with the tune. Most blow throughs NEED straightners, the less optimum the piping, the more they need them.
    Neat build anyway. Glad you went the upgraded IHI route. A lot easier with you package.
    Fairmont, WV
    2,467
    Thanks Bob!
    I did end up using an air straightener, and that's the OEM slot-style MAF sensor.
    Without the straightener it wouldn't run worth anything.
    If you still fight the tune (maf volts) consider adding another after the sensor as well. I have them on both my inlet and outlet side. I logged idle volts and both helped mine, and I have a "decent" location. also a finer honeycomb might help with the small sample inlet into the slot sensor.
    None the less, nice package (10#'s in a 5# bag :D )
    Still looks like a sleeper to me!
    Nicely done.....
    What kind of power and fuel mileage are you seeing?
    Fairmont, WV
    2,467
    The tune is great right now.
    I ended up tuning in open loop.
    When the ECU attempts to use the STFT from the O2 sensor it runs like crap.
    As soon as I take that O2 sensor out of the equation it smooths right out.
    I know it's due to the less than perfect MAF location, but man it's tuned SO well right now I hate to touch it!
    Fairmont, WV
    2,467
    Nicely done.....
    I can only estimate power numbers, so I won't say anything at all until I get to a dyno.
    Could be 215whp and could be 240whp. So many variables.
    Fuel mileage looks like around 28-30 range for highway, but closer to 28mpg.
    I'd say 32mpg could be possible in a flatter state!
    Not bad for tuned in open loop.
    3,316
    nice setup! Always had a soft spot for forcefed I4's :)
    Fairmont, WV
    2,467
    Sound of my BOV.
    Not a terribly exciting video but thought I'd share.:D
    [nomedia="http://www.youtube.com/watch?v=HfOz6Myj628"]YouTube- Tunnel_BOV.wmv[/nomedia]
    SexyManBeast KeystoneJohnny's Avatar
    Irwin
    888
    So how are you enjoying the seat of the pants factor.
    Toys:
    2013 Ford F-150 FX4 4x4 C.C.
    2010 Kawasaki Z1000
    Fairmont, WV
    2,467
    Quote Originally Posted by fordmanforever View Post
    Definitely fun. Will be even better once I open up the turbine side a bit more.
    Right now I believe it's limiting the flow to around 390-400cfm instead of the full 440cfm potential of the compressor side.
    Still good enough for 101mph in the 1/4, so I can't complain too much. :)
  1. Turbo Focus build #2
    By sutyak in forum Fox-SN95
    Last Post: 09-24-2012, 09:31 PM
  2. Latest upgrades..
    Last Post: 01-27-2009, 01:23 PM
  3. Ran the Turbo Focus: 14.74@95.97 (vid)
    By sutyak in forum Drag Racing
    Last Post: 09-03-2008, 06:03 PM
  4. My Turbo Focus vs Stang
    By sutyak in forum The Bar
    Last Post: 11-12-2007, 09:55 PM
  5. Turbo'd the Focus!
    Last Post: 08-22-2007, 09:47 PM
