Results 1 to 11 of 11
Thread: Degrees of total timing for peak horsepower
    Member Mark Aubele's Avatar
    Trafford, Pa
    2,308
    Thought it would be interesting to have a thread where people could discuss what total timing they arrived at through dyno testing, or track testing to arrive at maximum horsepower for different cylinder head applications. For example, on my old P headed combo we saw nearly no difference in peak or below the curve between 32-36 degrees of total timing, so we of course decided to run it at 32, and could actually get away with 87 in the tank every once in a while. My current TW headed combo seems to like a bit more timing, and is very sensitive to changes whereas the P heads really didn't care over a very wide range. Unfortunately, an issue with the summit balancer not discovered until I was at the dyno already prevented me from knowing the exact number the car made 347 hp peak at (stock short, N91, TW's, Victor jr, 750DP, and the wrong plugs, too short, I am an idiot) we just had to get close an move it back and forward until we arrived at a number. Anyone have any data they would like to add? Not too interested in initial, the standard "pull the spout and set it at 14" has been discussed many times.
    2014 M235i (wife's)
    1964 Ford F-100
    My current 9:1 AFR 185 comp headed 331 makes peak at 36*. We tried pulling it down to 34* and it lost HP and TQ. My dad's NA 347rwhp 302 made peak at 36* as well.
    36 deg on an iron headed (C8VE) BBF. Made no additional power at 38deg...lost 10 at 34deg. Bore is 4.36" and CR is 10.5:1.
    Jan 2008
    Jefferson
    4,674
    Yes I'm very curious what these 5.0 run. Timing wise.
    Here is a capture of my table ... remeber it's a big boost, 140 cubic inch, iron head combo
    it's soo-tack sutyak's Avatar
    Fairmont, WV
    2,467
    Bob what's your compression ratio?
    Mine's 10.1:1 and with 10psi I can only run about half that amount of timing before I get deto.
    Mechanical is 8.0:1
    For sure, and remember you have a MUCH better head design ... I am pretty good at 25 psi on pump gas with that compression, seems that going to 9.0:1 would boost limit me to about 20 psi with some assumptions. I could only imagine 10.X:1 With the new fuel capabilites (80# injectors) I will be playing with more boost and see if I need to take away timing.
    EDIT: sorry guys, just saw this was in the pushrod section, didn't mean to jac your thread.
    Trafford, Pa
    2,308
    No thread jack, very interesting post!
    2014 M235i (wife's)
    1964 Ford F-100
    my friends 93 stock short block liked 10 deg. initial we had it at 16 and kept backing it off on dyno and making more power , this was with tw track heat heads
    Trafford, Pa
    2,308
    My present combo oddly likes a ton of timing. I'm at 38 degrees total now. Will be ghetto tuning tomorrow morning by trap speeds at the hillclimb this weekend.
    2014 M235i (wife's)
    1964 Ford F-100
    Belle Vernon
    1,294
    My TW headed 347 na with 10.25CR likes 33-34 didnt make any more power on the dyno by increasing the timing.
    '89 Mustang GT
    '04.5 Duramax
    Jones Race Car Trailers
    www.jonesrv.com
  1. 4.6 horsepower add ons
    By 98gt in forum SN95-New Edge
    Last Post: 04-07-2012, 08:49 PM
  2. Starlite Horsepower night 8/19
    By map22 in forum Meets & Events
    Last Post: 08-17-2011, 12:41 PM
  3. 911 GT3 Pikes Peak record run
    By PaxtonShelby in forum Pictures & Videos
    Last Post: 04-11-2011, 01:33 AM
  4. What total timing is required for N/A engines?
    By snailmont5oh in forum Fox-SN95
    Last Post: 07-03-2009, 02:15 AM
  5. what is horsepower? part 1 the equation
    By George C in forum General Tech
    Last Post: 11-11-2006, 12:59 PM
