Results 1 to 20 of 22
Thread: installing front springs
    State College, PA
    3,552
    i bought H&R lowering springs, do i NEED a spring compresser for the fronts? if not, then how the fu*k do i do this? ive been trying for hours no luck. please help
    You can get a spring comp. at an auto parts store fairly cheap, why struggle with it? I got my cobra springs on without one, but every car is different..
    Member torqueboxer's Avatar
    white oak, pa
    638
    Maximum motorsports sells a little tab that bolts to the lower control arm that holds the spring in the lower spring pocket so you can just jack the lower and the springwont keep poping out. Or, get the internal spring compresser from the parts store compress the spring get it in the car, jack the lower up to hold it in. once the lower is jacked up with the spring in place knock the pins out that hold the compressor arms to the screw part then pull the compressor out the hole in the bottom. Hope this helps.
    Jun 2008
    Bloomfield
    31
    I didn't use a spring compressor because I couldn't find one that worked well enough to allow for the spring install without dropping the lower control arm. I eventually just dropped the lower control arm, put in the spring and used two floor jacks to push it back up into to place until I could bolt it back in. There's a few write-ups on Corral that gives the details.
    It's a bit of the pain in the ass the first time you do it, but I'd do it again knowing now how to get it done.
    93 GT
    Sep 2007
    Dayton PA
    3,795
    huge ass pry bar and a floor jack, put the top of the spring in first then pry the bottom into the a arm while you jack it up.
    03 Torch Red Anni. Ed. Cobra
    01 cobra: traded
    93 LX Modular 4v swap
    yep
    Haha, thats the way i do em
    JUNK IT!
    Modular Ford Performance Wolfpack Speed's Avatar
    4,321
    Quote Originally Posted by White5.0 View Post
    There is no need for a spring compressor to install lowering springs. As long as you have the strut and tie rod end disconected from the spindle, as well as the sway bar disconected from the end link, all you need is a pry bar to romove the oem springs. Depending on the lowering springs being installed, they will go in by hand or with very little effort via the pry bar.
    Mike
    Wolfpack Speed, Inc.
    4290 Campbells Run Rd
    Pittsburgh, PA 15205
    (412) 279-4902
    Built, Cammed, CCW'd SVT NateSVT's Avatar
    Monroeville
    856
    +1 Don't waste your money on a spring compressor. I've done spring installs on about 5 Cobras and never used one.
    2004 SVT Cobra - sold
    2000 Yamaha R1
    2006 Yamaha R1 - Raven
    10.89 @ 127.6 1.61 60' with a ported Eaton
    State College, PA
    3,552
    thanks for your input everyone...i rented a spring compressor from advance and wasnt able to use it because it kept hitting the kmember and while trying to push the spring into place....eventually was able to pry it in after working on it for a whole day. it kept popping out of the control arm. never doing that again LOL
    State College, PA
    3,552
    ooo ya one more question...do i need to put the stock spring dampers inside of my new springs or no?
    4,321
    Don't matter, I never do. You can also delete the isolaters for more of a drop. We do that for customers quite often...
    (412) 279-4902
    State College, PA
    3,552
    thanks mike. i didnt put them on, just wanted to make sure...ya i was thinking about going with no isolators but was woried it might be a little noisy without them. is this true?
    4,321
    I have done this on a couple of my personal cars without any ride or noise issues. None of my customers that have had me delete the isolators have ever complained or had issues that I am aware of.
    (412) 279-4902
    Jan 2008
    Jefferson
    4,674
    Rhino! Take the isolators out! Let's do it tonight! W0000t!
    State College, PA
    3,552
    Quote Originally Posted by 97LaserRed View Post
    haha FU*K that!!! ill never install front springs again lol... i think the only reason it was so hard is cause i didnt have a long enough pry bar.
    State College, PA
    3,552
    Quote Originally Posted by Wolfpack Speed View Post
    oo ok cool i wasnt sure. thanks for your input mike
    Sep 2007
    Dayton PA
    3,795
    haha i hate doing the front springs........especially when youre doing it by yourself, try prying and jacking the jack up with your foot
    01 cobra: traded
    The regular and lowering springs are not to bad at all. The drag launch spring kits can be a little tricky!
    Quote Originally Posted by SK@StreetLethal View Post
    Holy hell! Frank and I put a set of the Eibachs in my Capri ... uncut. Was one of the hariest things I've done. After we got one side done, we was affraid to do the other side :D
    4,321
    I HATE doing them!
    (412) 279-4902
  1. Upr Front springs
    By mooseman0 in forum Ford Vehicles
    Last Post: 06-20-2013, 05:09 AM
  2. Need 99-04 front coil springs
    By orangemachine in forum Ford Parts
    Last Post: 05-03-2011, 07:51 AM
  3. 89? V8 5.0 Hatchback / Coupe Front Springs
    By intel in forum Ford Vehicles
    Last Post: 12-28-2010, 12:27 AM
  4. Eibach launch springs (front)
    By Martin0660 in forum Ford Vehicles
    Last Post: 11-03-2010, 09:45 PM
  5. WTB: Front Lowering Springs
    By FrvrDreamin in forum Ford Parts
    Last Post: 03-23-2008, 05:14 AM
