Results 1 to 1 of 1
Thread: '85 mustang lx
    Aug 2009
    Ashland, Pa
    230
    '85 mustang lx
    327 stroker-all forged probe rotating assembly, 12.2-1 comp, internal balance, pioneer sfi approved damper, main girdle, windage tray, canton 7 qt oil pan, trick flow stage 3 cam, frpp double roller chain, edelbrock mechanical fuel pump, patriot heads, comp pro magnum 1.6 rockers, stud girdles, afr valve covers, parker funnelweb intake, pro systems dominator carb, msd 6al box, msd coil, msd billet distributor, aluminum underdrives, steeda tensioner pulley, aluminum radiator, flex a lite black magic foxbody fan, mac 1.75 prim tube longtubes, 3 in mac pro chamber, 3 inch mac catback with 3.5 stainless tips, new steering rack, flaming river steering arm, fidanza aluminum flywheel, ram powergrip clutch, astro performance super t-5, frpp aluminum driveshaft, 8.8 rear with 411 gears, 17x10 rear and 17x9 front ssc wheels, 5% tint all around, fiberglass 2.5" rr hood also not on the car 4 brand new greg weld prolites with lug nuts and washers, drive shaft loop, subframe connectors, g trac brace, have most receipts!! asking $12k
  1. Replies: 0
    Last Post: 09-01-2010, 11:35 AM
  2. More new Fox Mustang Parts @ Laurel Mountain Mustang
    Last Post: 01-29-2010, 11:36 AM
  3. 2003 Mustang Headlights Fits 99-04 Mustang.
    By KeystoneJohnny in forum Ford Vehicles
    Last Post: 03-14-2009, 08:08 PM
  4. MID-ATLANTIC MUSTANG CLUB Mustang Mall Drive (MD) June 28th
    By snakeyz 03 in forum Meets & Events
    Last Post: 06-16-2008, 04:01 PM
