Results 1 to 13 of 13
Thread: Trick Flow Pistions
    Trick Flow Pistions
    Has anyone ran these? I was going to build a new motor and the rest of my stuff is TFS, why not matching pistions! I cant find any reviews. I dont want to put KB pistions in this one...
    JE
    I don't run them, but they seem like a good choice. Only reason I didn't get them is because they were a little more expensive than others I was looking at. One nice thing about them is that they're a little higher compression than most other off the shelf pistons out there at 10:1. These are the ones I ended up using... http://www.dssracing.com/propiston.html
    Those are great pistons! The TFS pistions are cut for my heads....emmm a lot of lift!
    Only negative aspect of them is their portly weight. Can't remember the exact weight though. I *think* they are in the 550g+.
    Wow. the the Cheap Keith Blacks that I put in an old motor was the same.
    That may be with the pin though.
    Bet it was.
    I weighed those DSS ones and I'm pretty sure they were 200 grams lighter than stock and that was the cheaper ones. I'm sure the more expensive ones are even lighter.
    Member mlowry1260's Avatar
    Caledonia, Ontario
    620
    The TFS pistons used to be made by Arias. Not sure these days. Another good option is the Diamond TW specific piston. I wanted a flat-top with the correct notch for my 331. Nice pistons. www.diamondracing.net They have an online catalog.
    Another option is the Probe racing pistons. They're a little less costly & can be ordered with a second notch for the TW intake valve.
    These are both good forged pistons. I have some pics of my diamond pistons if your're interested.
    What's your application or intended use?
    Mark Lowry
    803
    JE
    Well, I dont know if I am going to with an aftermarket 302 or build a 9.5" based block. Either way, I want to build a nasty No2 Motor. I have never played with N02.
    Caledonia, Ontario
    620
    I have a friend that just piked up an all-forged low compression 427 (4.125" bore & 4" stroke) 9.5" dart block from Coast High Performance for under $5000. The 427 sbf is a great motor with decent compression height piston that allows enough room for a stout ring package. FWIW, I would stay a 4.1" or less with a N2O motor. BTW, a 4.1" stroke combined with a 4.125" bore yeild a 438" motor. You'd need to top that motor with a stout head like a AFR 225, CHI 225 or maybe a set of Victor Sr's for serious power.
    Set a goal & a budget. I like spending other people's money. Is this a street, street/strip or all-out race car?
    Mark Lowry
  1. FS: Trick Flow R Intake
    Last Post: 03-15-2013, 09:06 PM
  2. Trick flow heads
    By sinful rides in forum Ford Vehicles
    Last Post: 01-03-2009, 09:44 PM
  3. Trick Flow heads for 2v
    By Ares in forum SN95-New Edge
    Last Post: 12-24-2008, 08:30 AM
  4. trick flow box r
    By CESCO in forum Fox-SN95
    Last Post: 09-16-2008, 11:01 AM
  5. Trick Flow intake
    Last Post: 05-09-2008, 07:01 PM
