Results 1 to 10 of 10
Thread: Fixin some shit and upgrading any advice?
    Hey guys ive got a 2000 Gt convertable, the clutch recently started to slip so i decided to throw a new one in. This being my fisrt time messing with anything major under the car im havin some issues. I've got the new clutch disk and pressure plate installed and lined up but im having some major issues getting the tranny back up. Any recomendations? It's killin me havin the stang off the road for the past few days. :(
    fairmont,WV
    1,352
    be specific on the problems your having that will help us figure out the problem better
    XXX RWHP
    XXX RWTQ
    Sorry bout that guys. I've been messing with it all day its just every tight and the metal bracket that holds the clips for the O2 sensors was getting in the way. Thought I didnt have the clutch plate dead on but im pretty sure ill get it in now.
    But I did buy some Lincon Mark heads complete with timing assembly upper and lower intake throttlebody and and other things for 350 tho. Think of putting the 4v heads on her soon. I know this will be a big job but I picked up the parts real cheap so i figured it was something to look into and it opens the doors to alot as far as boost. Any ideas?
    You need to use a clutch alignment tool for the clutch disk...then tighten down your pressure plate to the flywheel. If you don't do that, you won't be able to get the tranny lined up.
    Yeah i have the pressure plate torqued to 12 pounds and It is aligned, figures my problem was the bracket that holds the 02 sensor plugs ended up wedged between the tranny and block in a spot i couldnt see it. Things are all sorted out now thanks thoo!
    that bracket sux big time
    lol yeah is it nessecary to have up there? because if not im just going to take it off and let the sensor plugs hang, they are disabled anyways seeing as i have no cats lol
    that bracket is for your upstream 02's....if you somehow disabled those you're going to be sorry. LOL
    You can remove the bracket though.
    Hmmm this is trueee, lol well the bracket is gone was to bent to salvage.
  1. Shit Happens Sometimes....
    By thedak in forum Pictures & Videos
    Last Post: 04-15-2011, 05:11 PM
  2. ok upgrading
    By thehill63 in forum General Tech
    Last Post: 04-26-2008, 07:31 AM
  3. Finally upgrading the rear suspension
    Last Post: 03-09-2008, 03:42 PM
  4. Upgrading to 10” Drums on a 87-93 Fox
    By DRRummel in forum Fox-SN95
    Last Post: 07-16-2007, 09:47 AM
  5. upgrading the alt.
    By J-rod in forum Fox-SN95
    Last Post: 03-25-2007, 11:33 PM
