Results 1 to 4 of 4
Thread: EGR Question?
    2turbos are better than 1 SilverFox's Avatar
    Bentleyville,PA
    75
    EGR Question?
    I have an 01 Cobra, and wondering if anyone had any experience with taking off the EGR valve, along with the tube down to the header. I know you would have to plug the tube fitting off at the header and make a plate to block off the hole in the manifold, but other than that what else can you take off ? Or will this mess something up?
    I'm going to get a custom tune this spring, will that take care of any problems?
    Thanks in advance
    Farmington WV
    4,672
    FORD sells an OEM EGR delete kit for $20. everything you need.
    remove EGR in tune and your fine.
    PART NUMBERS
    E69Z-9D440-A and W705609-S430
    was $18 for all. tax. ordered from my local ford dealer
    Power Adder
    236
    Like Jared said, Ford sells both parts needed to remove the EGR on mod motors. The only thing is, untill you get the chip you will have a check engine light for the EGR.
    Chris Kauffman
    1988 408LX drag car
    Bentleyville,PA
    75
    Thanks guys!
  1. egr delete
    By bluenotch in forum Fox-SN95
    Last Post: 02-13-2011, 02:12 PM
  2. WTB:EGR spacer or EGR delete plate 65mm or 70mm
    Last Post: 09-12-2010, 12:49 PM
  3. Egr
    Last Post: 09-03-2009, 10:55 AM
  4. Fox EGR
    Last Post: 10-22-2008, 09:01 PM
  5. Egr Elimantion Question
    Last Post: 10-13-2008, 05:16 PM
