Results 1 to 15 of 15
Thread: Pilot bearing problems..
    Thats the last time i rent a tool from advanced, the pilot bearing puller pretty much just destroyed the bearing instead of acutally pulling it out. Anyone have any other ideas on how to get A pilot bearing out? I'm going to try to find a better puller but this bearing is pretty shredded. Any quick fixes possibly?
    robinson
    1,091
    use a die grinder and cut a slit in the bearing. then pull it out. that is usually a last resort when you can't get them out or have nothing to grab onto for the puller to work.
    Quote Originally Posted by LS3GTO View Post
    "Sir, do you like getting killed by LSx powered vehicles ?"
    Quote Originally Posted by dannythekid View Post
    You can't swing a dead cat without hitting a car with a LS motor in it (Especially at 1st-Try!).
    /twocents
    Mt Pleasant, PA
    4,905
    I have 2 different pullers and have to use both to get the bearing out of mine. One always pulls the center bearing part out and then I use the other to get the outer part out. Its a real PITA, maybe someone else on here has experience with a better tool?
    Yeah the tool i used after about 5 tries just managed to pull the center out, other than that its been shredding the bearing. But thanks bg i'll try to get my hands on a grinder and get it out.
    And thanks sonic if you guys hear anything that would make it easier let me know. Id like to the the stang running for the wexford cruise tomorrow.
    Member HOTMARK7's Avatar
    BUTLER PA
    148
    Here is an easy way to get one out, pack inside of bearing with heavy grease, find a socket just smaller than the inside diameter of bearing, hit multiple times with brass hammer, replacing grease as needed, and bearing will pop out. I have done this multiple times and works great without destroying bearing.
    Senior Member 383taman's Avatar
    Jan 2007
    shaler,pa
    1,010
    Quote Originally Posted by HOTMARK7 View Post
    Thats how i get them out.
    89 Mustang (stock) DD
    82 Trans Am (not stock)
    98 Audi A4 (not so hurting)
    Well ill have to give that a try then! thanks guys
    x2!
    It makes a mess but it works if you can get something that is nearly the same size as the pilot bearing I.D.
    out in the woods
    4,948
    the grease works great, ive also just used a chisle,hammer and safety glasses to remove them.
    2003 polaris predator 500
    (wanna ride,just pm me!!!)
    State College, PA
    3,552
    using grease usually works but if it doesnt sometime the only thing to do is use a grinder and try to cut it, just be VERY careful not to hit the crank. i had to cut mine out when i was putting my car together. i tried for hours using other methods it just wouldnt budge
    Shes out worked like a charm. trannys back in with driveshaft and now its just time to put the H-pipe on and break in the clutch!
    Did you use the grease method?
    yupp. worked well. unlike that puller i rented.
    Jan 2007
    shaler,pa
    1,010
    Quote Originally Posted by Josh00 GT View Post
    Never had it fail me.
  1. Pilot bearing removal using bread (video)
    By Jomull55 in forum Pictures & Videos
    Last Post: 03-25-2011, 11:18 AM
  2. FS: 2 Michelin Pilot Sport Tires. 245-45-18
    Last Post: 05-21-2010, 12:59 PM
  3. pilot bearing I.D or shaft diameter question
    By jaa55 in forum General Tech
    Last Post: 01-25-2010, 10:41 PM
  4. Think your a Good pilot?
    By map351 in forum Pictures & Videos
    Last Post: 10-31-2008, 08:18 PM
  5. Michelin Pilot Sport 245/45/18 excellent $250
    By biminiLX in forum Ford Vehicles
    Last Post: 08-17-2008, 09:14 AM
