Results 1 to 20 of 22
Thread: 4.10 Gear Install
    Junior Member
    Elizabeth, PA
    6
    4.10 Gear Install
    Anyone know of a good place to get my 4.10's installed at that isnt going to break the bank?
    try any of the board vendors...
    Agreed.
    Matt
    94 Ford Ranger
    01 KX125
    NEWB 89stang's Avatar
    North Huntingdon
    1,136
    Whats not breaking the bank? Proabley will cost around 400.
    Member Mark Aubele's Avatar
    Trafford, Pa
    2,308
    Buy Ford gears and DIY. Simple to do.
    2014 M235i (wife's)
    1964 Ford F-100
    Polar Vortex
    6,031
    Cough, BS, Cough.
    Pay someone to do it unless you've watched other gear swaps done before.
    But yes ford gears are the way to go.
    www.wolfpackspeed.com
    Have Mike do them, he will do you a perfect job!
    1,301
    Agreed...and trying to get gears done on the cheap is a big gamble...spend the money the first time, and have them done right!
    1,301
    x2...
    Trafford, Pa
    2,308
    I think it is pretty well known that when you use Ford gears you can reuse all the shims and they are right 99% of the time. Really not rocket science, but if you have never done one before I guess it could be a bit difficult.
    2014 M235i (wife's)
    1964 Ford F-100
    Yeah and I also heard that Ford started having there gears made overseas so who knows how good they are anymore.
    Mt Pleasant
    2,916
    ive done many 8.8s and never had any issues. ive always used oem or ford motorsport gears...any retard could do it
    We just set mine up last night and had to move the pinion and ring gear about 10 thousandths each. Might have been better if I had the Ford gears and not the Ford Motorsport gears though I guess.
    Feb 2009
    Latrobe
    517
    Motorsport gears are the best gears to set up. Actually they are made on the same assembly line (or what ever you wanna call it). You set your pinion depth and you backlash with a dial indicator ( you wanted between 9.5 and 13 thousandths)
    PROBE PISTONS
    PROBE BILLET I BEAM
    super victor
    230cc CNC
    Hooker 2 in headers
    pa sc c4, 4600 stall
    9" LADDER 3.70 PRO GEARS
    SW BACKHALF
    moser 35 SPLINE axles
    1050 RACE DOMINATOR DEMON
    250 FOGGER KIT
    snow performance stage 2
    1.316 60ft 9.16@156
    Quote Originally Posted by 90TitaniumStang View Post
    Yeah, we were hoping everything would be the same since I was putting in the same ratio and they were both made by ford, but the lash was a little high and the pattern was way off. If they're made on the same line it's with different tooling because the gears were visibly different.
    My old pinion was F'd though... One tooth broken completely off and every other one had a very noticeable crack on the back side. I'm lucky I didn't break them all off
    for the cost of the gears/shims/oil/etc and my time to do the work....I would only use the correct tools and check the tolerances and patterns and not just slap them in and hope for the best....only thing worse than doing a job is doing it twice.
    Jan 2008
    Jefferson
    4,674
    ive done many 8.8s and never had any issues. Ive always used oem or ford motorsport gears...any retard could do it
    hahahahahahahahahahahha
    Better start checking as the last few gear sets I've had that were motorsport gear sets have measured way different. Pinion heads have not been as thick as the factory ones and as a result you need different shims.
    4,321
    There is a lot more to a good gear job then just swapping everything over and calling it good. I don't care what brand gears you use, if you know what you are doing, very rarely do any of them go in without some sort of adjustment.
    Feb 2009
    Latrobe
    517
    I agree if you dont have the correct tools dont try it. Its not worth the destroyed rea or other parts. If you do want to do them yourself. Spend the money and buy the correct tools. Dave reid and I just did a 2010 GT500 two nites ago. The stock gears had gear whine up top. When we were done no noise at all. The Ford Rotunda tool is the only way to go in conjunction with a good dial indicator.
    PROBE PISTONS
    PROBE BILLET I BEAM
    super victor
    230cc CNC
    Hooker 2 in headers
    SW BACKHALF
    250 FOGGER KIT
    1.316 60ft 9.16@156
  1. Gear Install Quote
    By Zoom50 in forum General Tech
    Last Post: 09-26-2014, 02:36 PM
  2. MX gear
    By scott5 in forum For Sale
    Last Post: 08-05-2009, 07:24 PM
  3. 4.10 gear install & Trac-Lok rebuild
    By wicked400ex in forum Wolfpack Speed
    Last Post: 04-24-2009, 02:16 PM
  4. Gear install
    By mustang50lx in forum General Tech
    Last Post: 06-05-2008, 10:11 PM
  5. gear install
    By A-Rex in forum Welcome New Members
    Last Post: 05-04-2008, 09:13 PM
