Results 1 to 2 of 2
Thread: Liquidate Time: Vortech V1 Si-Trim $1200
    Uniontown, PA
    135
    Need cash right away,
    Time to liquidate
    Head unit only $1000
    Kit as listed $1200
    Kit WITH modified 351 aluminum bracket $1600
    Prefer local pickup and cash.
    Can do paypal and shipping
    (can do VISA via paypal)
    Vortech V1 Si-Trim supercharger kit 86-93 Mustang –
    Purchased new in 03' as a SC-Trim and sent to Vortech to be upgraded to the Si-Trim in 08.
    Made 15psi on my 408 with 205cnc heads and Dyno'd at 700 RWHP, ran 10.3@139.
    INCLUDED:
    -head unit
    -front SC bracket
    -various bolts
    -alt bracket
    -belt tensioner bracket
    -3.00" 8rib high traction supercharger pulley
    -oil feed line
    -oil drain line and fittings
    -aluminum discharge tube (tapped for NOS and METH injection
    -SC belt tensioner/pulley (8rib) and aftermarket tensioner addition.
    -bypass
    -various intake tubing
    -FMU with several calibration discs
    NOT INCLUDED
    -AIR FILTER
    -SUPERCHARGER BELT
    -CRANK PULLEY
    -MOUNT BRACKET TO THE BLOCK (MINE HAS BEEN MODIFIED FOR A 351W AND I AM KEEING THAT)
    This is a well taken care of supercharger with about 6k miles, always garage kept Mustang. Oil changed
    often. This is not an old A-trim or S-trim, this is a V1 with the new Si impeller and volute
    Rated at 700+ HP.
    Selling as I am going bigger.
    Comp Cams hyd roller 230/240 .585/.585 114lsa cam - $150
    numbers from end of cam
    3636F/3638F/HR114 G7705-06
    MAF conversion harness and stock 55mm Mass airflow sensor $40
    96 Ford Probe GT wire set $5
    Stock 85-93 Mustang 5.0 distributor and cap (no rotor), MSD wire retainer $20
    BBK aluminum clutch quadrant $20
    A/C eliminator / Power supply relocation for 302 bracket - $10
    Keyless Entry system, never used, two FROBs, $20
    16 stock hydraulic lifters from 5.0, 100k miles, $20
    derekbellotti@atlanticbb.net
    Uniontown, PA
    1986 Mustang GT, 408, Vortech Si-Trim, TFS 205CNC, 373s, TKO500, AEM, 10.3@139
    Uniontown, PA
    135
    Or Best Offer
  1. Vortech Supercharger V1 Si-Trim 86-93 $1200
    Last Post: 07-31-2010, 05:59 PM
  2. Vortech S-Trim or SQ-Trim?
    By 95DropTop in forum The Bar
    Last Post: 01-18-2009, 09:33 PM
  3. FS: Vortech S-trim
    Last Post: 12-22-2008, 02:12 PM
  4. s-trim or t-trim vortech
    By crazylou in forum Fox-SN95
    Last Post: 12-03-2008, 09:07 PM
  5. Vortech S-trim
    Last Post: 03-14-2008, 06:45 AM
