Results 1 to 17 of 17
Thread: GT 500 guys look at this pic
    Senior Member Cam99's Avatar
    Melcroft
    4,178
    Thinking they are, but are these stock LCA's? They look different than I'm used to, but to flimsy to be aftermarket
    Bone stock
    Melcroft
    4,178
    Quote Originally Posted by Flyin Monkey View Post
    Bone stock
    Thanks for the quick responce. I had a feeling they were.
    Sep 2008
    555
    They are stock. Same shape and size as regular S197's, different color and bushings. I can't recall the exact substance of the bushings, but they're slightly stiffer than the others, but less forgiving than poly.
    Live free or die
    Aug 2008
    State College PA
    2,326
    I'll bet your car chatters like a son of a gun under hard acceleration! You must up grade them ASAP!
    PICS & Dyno
    Melcroft
    4,178
    Quote Originally Posted by mr4teth View Post
    actually hasn't been that bad. Is there a particular brand most guys are using? I think I had steeda on the Mach.
    I run the Steeda's that have the spherical bearing in the front.
    Senior Member SteelTownStang's Avatar
    Mar 2010
    Pittsburgh
    619
    BMR... adjustable if you plan to lower it...
    CAR: 2012 GT500 Black w/Grabber Blue Stripes (Sold)
    RECENT CAR: 2008 GT500 Red w/White Stripes
    PREVIOUS CAR: 2007 GT Black/Black
    MODS: VMP 2.59 Pulley & Tune, JLT Induction Tube, Airaid Blue SynthaMax Filter, Painted STB Brace, FRPP Springs, BRM Adjustable Panhard Bar, Borla S-Type Exhaust, 20% Window Tint, Speed Dawg Shifter, NXT Hood Lifts, CDC Dead Pedal, Kicker Speaker/Sub Upgrade, Cobra Floor Mats, 2013 Splitter, SVTPP Wheels & Tires, Cervini Tinted Taillights, V-Led 5K Fog Lights, etc.
    Melcroft
    4,178
    Quote Originally Posted by SteelTownStang View Post
    it's already lowered
    You don't need adjustable lower arms if it's lowered only the panhard needs to be adjustable.
    Sep 2008
    555
    I have Che's on ours now...squeak...squeak...squeak...these damn things seem to need greased once a month.
    You won't need adjustable control arms, but you may need lowering brackets for them. I've got Roush springs in the rear and it's only 1" lower, but the LCA's were no longer level. You may get some rear steer at higher speeds without them being level. It's just a sixxer, but the rear end bounced a good bit on hard takeoff with the stock arms and the GT500 arms.
    Live free or die
    Alloy Shelby 'Vert Orf's Avatar
    Dec 2006
    Hickory, PA
    37
    Watts Link. Much better.
    Agreed, but much more money too.
    joe THE BIG KOALA's Avatar
    Feb 2009
    Vandergrift
    1,117
    I put the UMI trac pack LCA,s with relocating brackets on mine and that ended the wheel hop all together
    2019 Hellcat
    Dec 2006
    Hickory, PA
    37
    Yes, but like I said on other boards, next to the TVS, the Watts was the best mod I did for my car. The difference in vehicle dynamics and response is amazing. If this is a drag car, the Watts may not be the way to go, though.
    Back to the original topic:
    I put the BMR LCAs on mine. Added the re-lo brackets when the FRPP Handling Pack went on 2 years ago. Added the adjustable Panhard then, too (but switched to the Watts a couple months back).
    Jan 2008
    Jefferson
    4,674
    The CHE do like to squeak! I want to change.
    Arch enemy of the Prius EricS197's Avatar
    Aug 2009
    Wellsville, OH
    266
    I have the Steeda LCA's on mine. Never did the relocation brackets since it was only lowered an inch (Supposedly not needed).
    On the GT500, I got BMR's set. When they came from Lethal Performance, one of the grease fittings was cross threaded... But after tapping the hole, the fitting screwed right in without a problem.
    I would go with BMR due to the grease fittings.
  1. FS: 2004 Cobra Coupe: Torch Red, stock, 14,500 miles; $23,500
    Last Post: 01-02-2010, 08:56 PM
  2. Need a pic
    By scott5 in forum Pictures & Videos
    Last Post: 07-30-2009, 01:15 PM
  3. one more pic before its gone
    By 92306gt in forum Pictures & Videos
    Last Post: 05-27-2009, 08:14 PM
  4. how do you take this pic? thanks for the pic bo lol
    By PunisherStang in forum The Bar
    Last Post: 08-21-2008, 01:40 PM
  5. new pic
    By M-dubb in forum Pictures & Videos
    Last Post: 06-30-2008, 10:11 PM
