Results 1 to 4 of 4
Thread: 1999 - 2004 Front Calipers on a SN-95?
    Cheap SOB
    Baltimore, Maryland 21236
    288
    I was recently talking to someone about retrofitting dual piston PBR calipers on the front of a single piston SN-95 brake setup. This said he used the dual piston calipers from 1999-2004 GT because they are very light, like 2lbs. He said it is made of aluminum and a direct bolt on. At the time I figured he might be BS’ing me. However, I now need to help a friend replace the front brakes on his 95 Mustang. So, is there any truth to this swap? A quick Google search did not turn up much.
    Yes they are aluminum and extremely light. 2lbs may be on the heavy side for the calipers. Unless the spindles are the same I can't see how swapping 99-04 front brakes onto an earlier Sn-95 can be a direct swap. If swapping entire assemblies, spindle and all then yes direct swap.
    Under PSI Black Vert's Avatar
    Cranberry Twp.
    344
    Yes you can swap them onto sn95 spindles but the spindles will need to be modified slightly. This link explains how http://home.comcast.net/~mjbobbitt/mustang/page14.html
    I have them on my '95 and as was said the spindle needs very minor trimming, and I mean minor. The weight savings is VERY minimal despite going with the aluminum caliper. I'll have to check but if memory serves me right I only saved like 4lbs total, and I weighed everything from the calipers, pads, etc. I did it for the weight savings and it wasn't anywhere near what I had heard and hoped for.
  1. 2003-2004 Cobra Mustang calipers / brackets OEM
    By roush08 in forum Ford Vehicles
    Last Post: 11-26-2014, 07:46 AM
  2. 1999-2004 stock taillights
    By 2000GT in forum Ford Vehicles
    Last Post: 09-01-2014, 08:46 PM
  3. 5 lug front spindles and calipers
    By TBone7281 in forum Ford Vehicles
    Last Post: 03-10-2013, 04:18 PM
  4. 94-98 front calipers
    By Stangzrule in forum Ford Vehicles
    Last Post: 05-21-2007, 02:36 PM
  5. 1999-2004 Gt front bumper cover
    Last Post: 11-18-2006, 06:54 PM
