Results 1 to 20 of 30
Thread: Drag radials??
    Drag radials??
    Alright so i got them on and went up to prp tonight, first time with drag radials and I just couldnt get the launch right. Kept spinning bad or bogging, any suggestions on what rpms to launch at? or maybe i should be heating them up a bit more im not so sure
    State College, PA
    3,552
    just gotta keep trying till you find the sweet spot. if your spinning try dropping it 500 rpm or so...if you start bogging pick it up a little. try to also keep the speed at which your dropping the clutch and how much gas you're giving it the same until you find what works.
    1,220
    I heat my Mickey Thompson DR's up until I see smoke in the mirror. You may need to heat yours up more. When I had a stick I launched at around 3500. I know other racers who launch at 5500 + RPM's with a stick.
    Nov 2008
    ELIZABETH TWP.
    885
    take air pressure out... seen u up their 2nite,i usually run 15psi in mine
    COREY...
    *04 Torch Red Cobra
    471hp/489tq
    Quote Originally Posted by crazylou View Post
    How's your car running Lou?
    What was your best time?
    never stock biminiLX's Avatar
    Beaver
    2,406
    What size tire and wheel? what psi and launch are you trying?
    DRs can be a tricky devil.
    I would launch my coupe at 5000-5300, had 12psi in drag radials, Hooked like a FREAK!!! 13.30s all day,.......not very fast, but always bit hard!!!
    JUNK IT!
    Jun 2007
    2,108
    Quote Originally Posted by How Much? View Post
    Impressive, what DRs?
    275-40-17 nittos
    JUNK IT!
    Jun 2007
    2,108
    275-40-17 nittos
    Very nice. I had 255/50/16 MT ET Street radials on my GT and I couldn't even dump it at 3500 without blowing the tires off. But I guess thats before PRP started actually prepping the track on TnT nights.
    Speaks the truth
    Dec 2008
    Natrona Heights PA
    3,056
    I ran Nitto Xtreme DR's for goin on 3years. Do standin still burnouts for at the least 10 seconds and or till smoke appears in the side mirror too. I run mine near 17psi usually. But I have had some decent runs around 15 and 20 also.
    Bu-2000-bash
    ALLSQUAD
    Steel City Muscle Cars
    CarCruises
    Flashlight Drags
    NMRA
    UMTR
    Modded Mustangs
    NHSCC
    Sorry for not postin on here guys, i recently switched jobs and ive been swamped! But yes I have the same problem mike had, i cant seem to break that 3500 rpm barrier without blowing the tires off, this past week at prp (26) I had a pretty damn good run of 13.7 launching at 3400 rpm with some wheel spin. The tires are 275/40/17 nitto 555r extreme drag radials. The car is slightly modded with 3.73 gears flowmaster 44s exhaust (no cats) short throw shifter, mac cold air w/ MAFS, and im beinging to wonder if the previous owner stroked it... the car is the loudest non-straight piped gt ive heard. But I've got no idea what this car will actually do if i could launch it at 5k+ and not break traction
    Beaver
    2,406
    Thats a relatively narrow, short Nitto---wish I could say anything other than good luck finding what works best. Take notes at the track might be helpful.
    I stuck with the 17inch rims due to tire price, $100 difference on each tire average, and im pretty sure 315s are gonna rub unless i move some things under there
    joe THE BIG KOALA's Avatar
    Feb 2009
    Vandergrift
    1,117
    Thats the exact same tire i run size and all. they are tricky to run but after 40 runs this year its getting better. I will be changing to the mickey thompson et streets after they wear out.
    2019 Hellcat
    I've run Nitto DR's for years. I've run 245-50-16 and 315-35-17 sizes. I went 1.72 with near stock suspension on the the 245's and 1.67 on the 315's. Here's what works best for me:
    -run no less than 17lbs of air
    -do a 2nd gear burnout for a solid 5-8 seconds
    -launch RPM is dependent on track temperature, ambient temperature, and surface prep
    In a stick car, if you shock the tires they will not hook. This means no clutch dumps. You must ride the clutch out enough to get the tires planted and weight shifted to the rear, then you can apply full power and fully disengage the clutch. This is the "trick" IMO to hooking on large diameter small sidewall DR's. Wheel hop can be an issue as well with DR's. From my experience if I experience wheel hop a HARDER launch cures the issue. I'm not sure why this is but it always holds true in my car. If I launch at say 4500 and it wheel hops, I will launch at 5000 on the next run and the hop will go away. If you run an on-off clutch like a spec, you may have real problems trying to hook as they are very hard to slip on a launch.
    Senior Member ocrowner's Avatar
    Jun 2009
    679
    very well said paul!
    come and get some!
    Jun 2007
    2,108
    Quote Originally Posted by ocrowner View Post
    I agree that has been what I'm trying to tell him. It has an OEM style clutch in it so it isn't an on/off switch. Just takes practice. DRs aren't forgiving like slicks.
    lol thanks guys, yeah ive been experimenting and I installed a sacks clutch in it recently. I did have some wheel hop issuse you can actually hear it in the video like i said but im guessing just use a hard launch and moderate clutch slide. oh and one last thing ive been havin issues with the 2nd gear burnouts because the car loves to slide out on em and it doesnt respond very much to correction unfortunatly should I let it start to slide forward farther out of the water or will that just bog down the engine if the tires get sticky
  1. Drag radials - which is better ?
    By roush08 in forum Drag Racing
    Last Post: 08-19-2012, 12:04 PM
  2. drag radials
    By TBone7281 in forum Ford Vehicles
    Last Post: 09-03-2011, 09:41 PM
  3. FS: MT Drag Radials
    By SoLow in forum Ford Vehicles
    Last Post: 09-18-2009, 05:20 PM
  4. Drag radials
    Last Post: 07-28-2008, 10:32 AM
  5. What Drag Radials ?
    By molnartr in forum General Tech
    Last Post: 12-30-2007, 04:43 PM
