Results 1 to 5 of 5
Thread: 5 Lug Conversion Question
    Ninja
    Cranberry
    331
    Does anybody know if rear axles out of a 99 ranger w/ the 7.5" rearend would work to do a 5 lug swap on my 85 mustang gt? My 85 has the 8.8" rear. I read that two driver side axles out of earlier rangers would work but I'm not sure about these. If anyone knows if the 7.5" or 8.8" axles out of a 99 ranger would work i would appreciate the advice.
    Thanks
    -Kevin
    1985 Mustang GT:Cobra r's.full exhaust.8.8 w/ 3.73's.forged 306 c.i..
    Feb 2009
    Latrobe
    517
    im looking for some 31 spline moser with eliminators if i can find some ill sell ya my 28 spline 5 lug axles
    PROBE PISTONS
    PROBE BILLET I BEAM
    super victor
    230cc CNC
    Hooker 2 in headers
    pa sc c4, 4600 stall
    9" LADDER 3.70 PRO GEARS
    SW BACKHALF
    moser 35 SPLINE axles
    1050 RACE DOMINATOR DEMON
    250 FOGGER KIT
    snow performance stage 2
    1.316 60ft 9.16@156
    Feb 2009
    219
    I had this saved in My Docs folder...
    To convert the rear end to 5-lugs you need to replace the 4-lug axles and drums with 5-lug units. The axles that are needed will be either off of a Ranger, Bronco II or Aerostar van. From an '83 to '92 4 cylinder or 3.0L V6 Ranger/Bronco II with a 7.5" rear end you will need two driver's side axles. Only the driver's side will work as the pumpkin on these rear ends is offset and the axles are different lengths (you need the longer of the two axles). It should measure 29-5/32".
    From an Aerostar you will need two of the passenger side axles from an 86 to 97 model. The axles are all the same so they can be mix-matched (i.e. - one driver's side axle from a Ranger and one passenger side axle from an Aerostar). You can use the brake drums from either side of the above listed vehicles but make sure that they are 9" drums. The 4.0L Rangers came with an 8.8" rear end with 10" drums - these will not work.
    Under PSI Black Vert's Avatar
    Cranberry Twp.
    344
    Everything you need to know is in here http://home.comcast.net/~mjbobbitt/mustang/page1.html
    Senior Member oldfox's Avatar
    May 2009
    296
    I got a set that I used before I switched to disc all the way around $70 and shipping have the drums also if you need them
    304-478-4430 Lee
  1. Replies: 5
    Last Post: 03-21-2014, 11:25 AM
  2. rear 5 lug conversion
    By yeahloh95 in forum Ford Vehicles
    Last Post: 08-07-2012, 11:12 AM
  3. another conversion question
    Last Post: 03-23-2008, 01:18 AM
  4. ? about 5 lug conversion
    Last Post: 12-10-2007, 06:48 PM
  5. 5 lug conversion / brake question
    By Stangzrule in forum Fox-SN95
    Last Post: 04-01-2007, 09:39 PM
