Results 1 to 7 of 7
Thread: 8.8 upper bushing removal
    Sep 2007
    Homestead
    780
    Has anyone removed these without buying the bushing removal tool ?
    I got the rubber out easily but the shell is a different story. I don't want to beat on it and end up breaking off an ear.
    Anyone have the tool and want to rent it to me so I don't have to spend $40.00 for a tool I'm only going to use once ?
    Jan 2008
    Jefferson
    4,674
    use a drill and drill holes through it and hammer it out
    Sep 2007
    Homestead
    780
    I'll still need the tool to install the new ones, right ?
    Member badstanglx's Avatar
    altoona
    676
    use a ball joint tool works great i did it
    Take a saw or sawzall and cut a slit in the shell and it will come out easily.
    I own the MM tool but it out on loan. I've never used it to re-install them as I use Baselines uppers and the use a solid insert.
    Feb 2009
    Latrobe
    517
    Quote Originally Posted by SK@StreetLethal View Post
    yep and then you just knock them out with a hammer and chisel
    PROBE PISTONS
    PROBE BILLET I BEAM
    super victor
    230cc CNC
    Hooker 2 in headers
    pa sc c4, 4600 stall
    9" LADDER 3.70 PRO GEARS
    SW BACKHALF
    moser 35 SPLINE axles
    1050 RACE DOMINATOR DEMON
    250 FOGGER KIT
    snow performance stage 2
    1.316 60ft 9.16@156
  1. tailshaft bushing removal tool
    By 03gtsc in forum SN95-New Edge
    Last Post: 09-17-2014, 11:47 AM
  2. tailshaft bushing removal tool
    By 03gtsc in forum Ford Parts
    Last Post: 09-17-2014, 11:45 AM
  3. Bushing Kit
    Last Post: 05-20-2011, 03:59 PM
  4. Rear axle upper bushing removal
    By gmslayer in forum General Tech
    Last Post: 07-17-2009, 06:38 PM
  5. control arm bushing question
    Last Post: 06-24-2008, 09:58 PM
