Results 1 to 6 of 6
Thread: 91 gt engine upgrade advice needed
    Aug 2010
    connellsville
    160
    Hi guys i got a 91 gt with the stock 5.0 HO i'm looking to get a set of gt40 heads for it through summit but i'm not sure what cam i should go with on this application i'm also planning to get an engine rebuild kit through summit something that includes new pistons and rings the works any advice would be really helpful since i'm just getting into building thanks. also will the stock rockers work on these heads or will i need upgrade on those also.
    never stock biminiLX's Avatar
    Beaver
    2,406
    First, what are the goals for power and budget?
    I personally would never buy GT40 heads new, there are SO many better choices and you can save good weight with aluminum heads.
    Does the engine need a rebuild?
    Aug 2010
    connellsville
    160
    yeah it does need a rebuild. for now i just want to get that done and at least get a decent set of heads and cam i'm looking to drop about 2000 into the engine and try to get about 300+ total hp out of it. but i want something that i can still run regular gas (89-93) octane if you have any ideas on rebuild kits i should go with or good heads and cam just let me know thanks.
    engine
    do some shop'n around!!! you can pick up a low mile longblock pretty cheap, throw a Motorsport cam in it, with a 100shot N.O.S. and be hittn 12's all day!!! Even look around and ask some machine shops, i picked up a roller 302 that a guy had rebuilt, but never paid and it sat there for a year......they tried getting ahold of him one last time, then i got it for $700.....
    JUNK IT!
    Quote Originally Posted by geps91stang View Post
    You can get it done with $2000 .......gt40s from a xplorer, use the intake, get the N.O.S. kit, get rid of smog(but save the parts you take off) Electric fan, Bump the timing ...........YOU CAN DO IT!!!
    JUNK IT!
    NEWB 89stang's Avatar
    North Huntingdon
    1,136
    Here you go send him a pm complete motor for a good price and better heads than the gt-40's plus if its in the car still you can hear it run!
    http://www.steelcitystangs.com/forum...ad.php?t=20544
  1. Handgun advice needed
    By Killercanary in forum The Bar
    Last Post: 02-23-2012, 01:02 AM
  2. Rifle Advice Needed
    Last Post: 11-27-2011, 10:20 AM
  3. Advice Needed: My car is in a closed up shop
    By DRRummel in forum The Bar
    Last Post: 01-01-2009, 12:04 PM
  4. Replies: 25
    Last Post: 12-24-2008, 04:06 PM
  5. Replies: 2
    Last Post: 02-27-2007, 04:08 PM
