Results 1 to 8 of 8
Thread: fox body bouncing speedo needle
    1,164
    i am having issues with the one fox body and the speedometer needle bouncing.
    any ideas on where i should start to look?
    Somerset Co.
    2,907
    Cable might be sticking.
    Member badstanglx's Avatar
    altoona
    676
    put a new speedo gear in it and ate teeth off it!!!!!
    Fort Eustis, VA
    525
    I'd say check the speedo gear as already suggested and then if not the cable. is it making a chattering sound when its jumping?
    86 Notch New Project
    1,164
    No sound
    Fort Eustis, VA
    525
    Then I would say speedo gear first, then the cable, I had problems with my cable sticking like speedracer stated.
    I found out that the inside of the cable started corroding and was sticking to the outter shell of the cable causing the speedo to jump. It would jump until it got past like 15-20 mph then it would stop.
    State College, PA
    3,552
    most likely the speedo gear itself.... after that i would say its the cable as already stated
    Big member venom's Avatar
    North Fayette Township, PA
    1,344
    My 91 started bouncing after 55 mph. I changed the speedo gear in the transmission and the cable, but that didnt help at all. Mine seemed to be in the actual speedo.
    2015 GTPP
  1. My old car's bouncing around Craigslist.
    By Mitternacht in forum Pictures & Videos
    Last Post: 10-30-2010, 09:03 AM
  2. 140 speedo fox
    By wick in forum Ford Vehicles
    Last Post: 02-01-2010, 11:21 PM
  3. Needle in the hay stack!
    By map351 in forum The Bar
    Last Post: 11-11-2008, 08:07 PM
  4. fox speedo cable
    By J-rod in forum Ford Vehicles
    Last Post: 11-17-2007, 09:45 PM
  5. fox Speedo cable
    By cc4x4rider in forum Fox-SN95
    Last Post: 08-02-2007, 08:48 PM
