Results 1 to 13 of 13
Thread: Battery Shut Off
    Battery Shut Off
    Just curious what the rules are when the battery has been relocated to the trunk. Is this needed even if the car is pretty slow(13-14 second range)? I just bought a car that was most likely fast before, but not so much now, lol. It's got an 8 point cage and the battery is in the trunk but the motor is a stock long block 5.0 with a cam.
    2,103
    Yes to run at the track, if the battery is in the trunk, you need a properly and clearly labeled shut off switch. Had to go through that with Tonys car when he did it.
    03 Cobra=slow show car...
    13 F-150 Limited
    2,103
    Oh and where are the pics at??
    13 F-150 Limited
    Jun 2007
    N. Huntingdon
    1,596
    AFAIK if you turn quicker than 12.99, you need an external shutoff switch. I don't think one is mandatory just because the battery is in the trunk.
    Chris
    2016 Chevrolet Volt
    2010 Jetta TDi Cup Edition
    1964 Lincoln Continental
    Quote Originally Posted by Mitternacht View Post
    If the battery is moved to the trunk, a labeled cut off is required regardless of ET / MPH. Not only does it need to kill the battery, but it must also kill the ignition (shut car down).
    Jun 2007
    N. Huntingdon
    1,596
    Huh, never knew it was mandatory.
    Chris
    2016 Chevrolet Volt
    In addition to what Bob said, passenger compartment must be protected by a firewall of .024 thick steel or .032 thick aluminum. I believe the accepted battery boxes eliminate that requirement, though I can't get on IHRA's site at the moment to verify that. The IHRA rulebook is on the Competition page of www.ihra.com
    ChuckT
    Sponsored by
    Millerstown Pic A Part
    Thanks for the info guys. I assumed I would need one regardless of speed, but I was just hoping there might be like a 12.99 stipulation like Mitternacht was saying. Guess I'll have to order some parts before I can get some baseline runs.
    I tried looking there, but I couldn't seem to find what I was looking for. You think a back seat(which I don't have right now) or a piece of plywood would do for the firewall?
    I'm gonna try to get some pics up later today or tomorrow. Here's a cell pic from today at lunch...
    2,103
    Is the battery just sitting back there? If it doesn't have a box, I would buy a battery box and shutoff switch kit. They are cheap enough.
    13 F-150 Limited
    It looks pretty securely mounted. It looks like whoever had the car before me knew how to weld pretty well or at least knew someone who did. It's got a custom 8 point cage and looks like they welded up a custom battery "frame"(it's like a little mini cage for the battery). The battery is exposed though. I'm thinking about getting a cheap battery disconnect that I can just put behind the plate so when/if I go to the track I'll just put the plate in the window and mount up the shutoff temporarily.
    http://www.mydigitalpublication.com/...on/?m=1203&l=1
    is a direct link to the rulebook. At the contents tab at the top of the page, you want "General Regulations - All Classes".
    I don't think a firewall made of a flamable material would pass. Same with just a back seat, also flamable. The box is your best bet... simple and effective, mimimal modifications needed. Something like this for the box:
    http://www.summitracing.com/parts/SUM-G1231/
    Switch like this:
    http://www.summitracing.com/parts/SUM-G1432/
    Still has to be wired correctly to shut the car off when the switch is turned off.
    Larry DePretis is the tech director at PRP, and he can help answer specific questions for tech:
    larry@pittsburghracewaypark.com
    ChuckT
    Sponsored by
    Jun 2007
    N. Huntingdon
    1,596
    Is that picture from the Pittsburgh Mills?
    Chris
    2016 Chevrolet Volt
    Switch like this:
    Thanks again!
    Yep, went to Lowes at lunch to try and get a key made
  1. Replies: 8
    Last Post: 02-10-2013, 09:03 PM
  2. Can TPMS be shut off with a handheld tuner?
    By FineLineMtrSprt in forum S197
    Last Post: 03-01-2012, 10:00 AM
  3. Replies: 88
    Last Post: 02-02-2007, 11:57 AM
  4. Stock Fuel Shut Off
    Last Post: 10-23-2006, 12:15 AM
