Page 3 of 3 FirstFirst 123
Results 41 to 46 of 46
Thread: Spun axle tube
  1. #41
    Bob, is more rpm the solution? :D
    I thought we resolved that question earlier in this thread ...
    Well, it's apparent that it wasn't enough RPM in the first place. If it was, it would of spun the tires and not the axle tube ;)
    Ed... say it with me... au-toe-mat-ic!!!
    Ah man .... That's like 30 whacks with a Hurst shiter handle for that blasphemy.
  2. #42
    LMAO Bob!
    ChuckT
    Sponsored by
    Millerstown Pic A Part
  3. #43
    Well finally got a chance to get rear cleaned and back together. I did get right side of diff apart to check over. Ended up deburring the gears inside. I tried to get left side cover off but the bolts were tight and I had no way of holding it without screwing it up so screw it. I'm not all worried over diff as a I will be putting 33spline axles and spool in over winter. Just need to get lower control arms. Either UPR(had a set but I think I tossed them, gonna look again) or TeamZ lowers.
    DONE! (well pic was before I got the wheel studs in axle)
  4. #44
    never stock biminiLX's Avatar
    Beaver
    2,406
    Looking MUCH better.
    Now, what's the cottage cheese for? :)
  5. #45
    That's for bolts.
  6. #46
    Got home from Redwing, MN about 5am and in bed till 11am then went over to work and got rest finished off to get it drivable.
    Got new LCA's from UPR so I need to yank the Steeda's back out and toss them in scrap pile once I get car over to my dads. Also will have to clean off some paint on the tubes and get my brackets for braces welded on.
    Now for a few nice saterdays to try for 11's.
  1. Tube k member.
    By bluenotch in forum Ford Parts
    Last Post: 07-03-2013, 07:06 AM
  2. 1 5/8's long tube headers
    By HidalgoGT in forum Ford Parts
    Last Post: 05-11-2008, 04:05 PM
  3. NEED: EGR Emissions Tube
    Last Post: 11-27-2007, 10:16 PM
  4. Spun the rollers down at Hybrid to the tune of:
    Last Post: 10-09-2007, 09:44 PM
  5. 3" over axle tailpipes & under axle anti-roll
    Last Post: 05-03-2007, 11:11 AM
