Results 1 to 9 of 9
Thread: pcm help
    butler pa
    337
    pcm help
    I was testing my sensors and none of the voltages where in range is this a sign of a bad pcm I check for bare wires and found none mabey someone can help me
    Lovin my 302
    Chicora, Pa
    116
    Check pcm ground
    butler pa
    337
    Fixed pulled the covor and there a burnt chip don't know how it was running....... on to the next prolbem I replaced my belt tensionor becaue my alt keep droping at red light it is still doing this I tested it it says its ok but when you put it in drive and have the lights on it says I not good anyone ever had this happen to them lead me t some insight
    Quote Originally Posted by 94gt5.0 View Post
    Had this happening in my old 02 a while ago. ran fine with lights off and with the brakes not engaged. As soon as you touched the brakes it dropped quick, couldnt even get it out of P without it dying. Took off my alt pulley (was a summit underdrive kit), replaced alt and battery and it was alright for a while and started soon before I wrecked it..hopefully someone else will have better insight.
    Matt
    94 Ford Ranger
    01 KX125
    Lovin my 302
    Chicora, Pa
    116
    I have the same problem
    Jun 2007
    2,108
    Quote Originally Posted by 955.0 View Post
    I am having shitty voltage problems as well. Car doesn't die but voltage gets extremely low with load on the system. Did it with the old alternator before it went, new one does the same thing. Its a new battery too.
    Lovin my 302
    Chicora, Pa
    116
    Same deal here, new battery and new alternator but still same old trouble radio even cuts out
    1,220
    I was having voltage problems. Got rid of the underdrive pulleys and the problem is gone.
    butler pa
    337
    Well I guess this is a common prolbem I'm running stock pulleys
  1. Copperhead pcm 8,200 RPM
    Last Post: 08-11-2011, 07:55 AM
  2. 96 97 98 FORD Mustang GT 5spd 4.6 5.4 MAF PCM / ECU P/S
    By onenastytbird in forum Ford Vehicles
    Last Post: 10-08-2009, 03:49 PM
  3. 98 Mustang 4.6 MAF, PCM and P/S Resovoir(NEW) "LOT"
    Last Post: 07-30-2009, 03:32 PM
  4. Wanted C3w Pcm Computer
    By blkp42e in forum Ford Parts
    Last Post: 09-05-2008, 11:39 AM
  5. PCM, FOR 2000 gt
    By Rodeheaver's in forum Ford Parts
    Last Post: 11-17-2006, 10:42 AM
