Results 1 to 3 of 3
Thread: 1993 Mustang Gt Hatchback
    Junior Member
    Feb 2010
    Butler
    1
    I want to buy a set of slicks for my car 1993 mustang GT Hatchback ..I have set of 26x9x15 quick time pro DOT Hoosiers can't get them to bite or stick spinning out of the hole 60ft time sucks played with air up and down 12psi to 25psi stayed at 18psi ok time ?50/50 shocks in rear and 90/10 up front .What slicks will fit will 28x10.5x15 M/T ET Drag the section width 11.70... my rim size is 15x8 /4.5 in deep rim (postive) I was concered about the tire rubbing against my outer fender or inner fender wall any ideas.....
    Some random thoughts ....
    If your current tires are Quick time Pro's, then they are 26-9.50-15. As a benchmark, these are really a 26-8 slick width (8" tread width).
    The best fit for a fox car to get tires under it is 15 x 8 with 5.5 Backspace. I am ASSuming your wheels are 15 x 8 with 4.5 Backspace???? If so you are correct to worry about clearance in the front.
    Rob (Wick) has the longer axles with rear disc's on his car. This makes the wheel flange stick out 3/4" more than a normal fox. My 15 x 8 5.5 BS wheel fit okay on there with my 26-9-15 slicks. This is about a 1/4" less than your 4.5 BS wheels so even they would be tight. There is no chance to get my 26-10 slicks under his car IMO (lowered)
    Are you opposed to buying a set of 15 x 8 x 5.5 BS wheels??? This would then let you run a 26-10 slick, a 26-11.50 QTP, or a 275/50/15 radial (all 10" wide rubber). The extra inch of BS will open the world to wider and taller tires for you.
    Another option a little better is to look to Mickey Thompson for either their 26-8.5 slicks or a 26-10.50-15 ET Street. I am almost certain that these will not fit well as Shaun (libstang) has been paranoid about using that same combo (4.5 BS wheel and 26-10.50 ETS). Some heavy outside rolling might make it work, but ....
    I will also tell you that the QTP's will hook like mad, but are VERY sensitive to burnout process if you are under tired. Go to the Hoosier site and read thier burn out process and follow it. You might be suprised how your 60's pick up.
    Member DING's Avatar
    New Bern, NC
    324
    I have used a few different back spaces 15x8 4.5 / 15x8 5.5 / 15x10 5.5 & 6.5 with 28x 10.5 slicks. And they ALL require a 5lb sledge to the inner fender well around the shock support and rolling the fender well on the quarter panel. Both jobs are not that bad, just do not cut the lip on the inner fender and then roll it. It will cause the outside of the wheel well to crease and look like shit.
    One thing to look at if you want to run a slick is a 15x8 5.5 BS and a 28x9 slick then you really only have to smack the high spots on the inner fender around the shock tower in a little.
    Hank
  1. 1993 hatchback headliner-non sunroof
    By PSPstang in forum Ford Vehicles
    Last Post: 11-23-2013, 08:22 PM
  2. 90 mustang lx hatchback
    By badstanglx in forum Ford Vehicles
    Last Post: 07-27-2013, 08:27 PM
  3. 92 Mustang 5.0 lx hatchback NO Title
    By lib88stang in forum Ford Vehicles
    Last Post: 07-22-2013, 11:00 PM
  4. 1989 ford mustang lx 5.0 5sp hatchback
    By thebreeze72 in forum Ford Vehicles
    Last Post: 07-14-2008, 01:25 PM
  5. Dismantiling 1993 Mustang Hatchback.
    By looselugnutz in forum Ford Vehicles
    Last Post: 05-18-2007, 06:11 PM
