Results 1 to 6 of 6
Thread: Need advice for good rotating assembly (piston,rod,crank)............
    Crazy Bosnian Slow5.0's Avatar
    Erie , PA
    74
    Well i decide to go with Dart Sportsman 302 block
    Now i have to figure out what internals i gonna use
    Its gonna be bosted motor so everything have to be very good stuff forged
    For HP # ,i don't know how high i wanna go but i wanna have space for more so i don't care if is over kill ,because this motor have to produce some crazy power
    Heads i gonna use most likely gonna be TFS TW R
    BTW its not race motor since its gonna be in street Stang that will see track once or twice a month
    Anyway HP #s i looking for are 650+ and money its not problem
    So who makes good internals and what are good combos
    Thank you
    BTW should i go with internaly ballanced or not
    Ernan aka Ernie
    '94 GT Vert
    12.76 @ 105 w/ bad clutch 4050lbs 1.8 60FT
    TW heads,B-31 AFM cam..... MORE
    312HP / 340TQ with safe tune
    "A few" pics of my car
    My "Slow5.0 Compilation" video from the begining
    My "Slow5.0 Dyno Compilation" video
    04 Lincoln Navi
    WTB 94-95 5.0 smog pump
    I went with a Eagle Forged Crank, Eagle H-Beam Rods and Custom Forged JE Pistons for my 331. It is internally balanced, which I would recomend for your application as well.
    I would suggest contacting Ron @ Fox Lake if you plan on running the TW Heads. He's the guru on them!
    Power Adder
    236
    I like the eagle products (I have there 408 forged stroker kit in my 88), but with your goal of 650+ hp I wouldn't go with eagle H beam rods. I'd go with a good billet rod like manley pro I beam rod. I had eagle rods for my 00GT, but sold them and bought some pro I beams with pistons after a customer folded a eagle H beam rod and wiped his block out in his high powered turbo car. They are rock solid rods and will take abuse, but they are about twice as much(about $1200 just for the rods). For pistons I'd go with the JE or CP pistons.
    Chris Kauffman
    1988 408LX drag car
    I have very similar goals to you Ernan and I went with 4340 forged scat crank and H beam rods with ARP 2000 rod bolts and JE SRP pistons. If I could have changed anything it may have been the pistons but these will still due for what my goals are. My rotating assembly is internally balanced, I felt this was best even though I don't plan to rev it very high. Like Ed I recommend you do this as well. I got my stuff from Kevin at http://www.kskustoms.com and I had it assembled by Rick at RNH performance.
    Erie , PA
    74
    Thank you guys ,thank you Paul
    But one thing , isn't H beam rod stronger than I beam
    And Chris00GT whats reason i should go with I beam rod
    Ernan aka Ernie
    '94 GT Vert
    04 Lincoln Navi
    Power Adder
    236
    The eagle H beam rod is rated to around 700hp and is what we used with great results on most engine rebuilds. Some I beams are what we would use on motors who have a higher hp goal or want the stronger rod. The Manley Pro I beam is rated to 1200hp. The manley rods were alot beefer and weighed more than my H beam eagle rods. Places like Bennett Racing go from H beams on their normal engines to Oliver billet I beam rods on their higher power street engines.
    Chris Kauffman
    1988 408LX drag car
  1. 345 Rotating assembly Forged everything
    Last Post: 06-30-2014, 08:25 PM
  2. For sale ford A4 block with 331 rotating assembly
    By OneBad95 in forum Ford Vehicles
    Last Post: 08-25-2013, 01:05 PM
  3. FS: 302 Rotating Assembly
    Last Post: 09-17-2009, 10:39 AM
  4. Replies: 3
    Last Post: 10-16-2008, 09:09 AM
  5. Forged rotating assembly
    By Mitternacht in forum S197
    Last Post: 04-21-2008, 06:26 PM
