Results 1 to 19 of 19
Thread: HELP!!!! Sometimes overheating....
    Jan 2008
    Jefferson
    4,674
    Thumbs down HELP!!!! Sometimes overheating....
    OK sometimes my car will over heat driving normal and after beating on it. really depends on the temp outside...(i think) not exactly sure what it could be.. looking for some help or ideas on what to check because I DONT WANT TO THROW PARTS AT IT. Here is what I know.
    The fan is working. If i were to just turn the car on with a/c on the fan will turn on. So that means the CCRM is working right? the heat and a/c in the cabin are perfect. I have the fan temps to come on at 180* low speed 200*high speed.
    The coolant level is full. no air pockets. Ive check numerous times. Now I did put a new coolant res cap on it (pepboys) because I heard the Ford cap leaking one day when I turned the car off. I could hear a very slight hiss from the cap. maybe the pepboys cap is garbage.
    Now yesterday when I got home I checked under the hood and noticed coolant around my pepboys cap.
    Now one reason it could be heating up is because i have a big ass space heater that puts out 80 million BTU's in between the motor and fan!!!! but I wouldn't think it would affect it that much?????
    It has a cobra radiator and all the cobra cooling elements. Now should I put a 160* t-stat in it?, Turbo blanket?, bigger rad?, new cap? like I said I dont want to throw parts at it so help me diag it so I know what to do.
    Thanks!
    My temps usually would stay about the "O" on the "NORMAL" but lately they would go to about the "M-A"
    Jan 2008
    Jefferson
    4,674
    I know some people are going to tell me to get a new fan right of the bat but why? makes no sense. If my fan is turning on how could it not be working correctly? The fan is from my v6 motor. I am 99% sure. Everything else is cobra equip
    robinson
    1,091
    personally i don't think you would go wrong with a turbo blanket. i run them on all the customers car more less. and the underhood temps drop dramatically. but need the good type what is held on with wire ties sold through modular turbo and places liek that.
    does the temp climb gradually? or spike?
    slower speed driving? do you have the front air dam under the rad support? that will affect your cooling a bit without realizing how miportant it is.
    Quote Originally Posted by LS3GTO View Post
    "Sir, do you like getting killed by LSx powered vehicles ?"
    Quote Originally Posted by dannythekid View Post
    You can't swing a dead cat without hitting a car with a LS motor in it (Especially at 1st-Try!).
    /twocents
    Jeff has some good points...
    I agree on the turbo blanket....not saying that is the only problem, but think about how hot it gets and it's location.
    Installing a real coolant temp gauge with numbers is a good idea as well. In fact i would consider both of these a necessity.
    Reinstall the air dam if it's missing...
    Borrow the res cap off of Bo's car and try his...you're throwing parts at yours for free.
    I bought a res off you a while back because mine had a leak that was really hard to find. It would only leak when driving the car (could idle all day long not problem) and I finally figured out it was where the two res halfs come together...it would expand when hot and the coolant would leak out there.
    You said cobra rad....03/04? I ran that on my 99 and it's a nice piece compared to a stock 99 cobra rad (which I believe is the same rad as 99-04 GT's).
    Wrap that piping and turbo. All of that underhood heat is what is most likely causing those issues. We still have the stock radiator in Craigs car and it works great. Although I would'nt rule out a sticky thermostat. Oem ford thermostats are the best out there it seems. Even with stants we have had issues. I won't even talk about the autozone brand...
    robinson
    1,091
    truth about thermostats. i forget what they said the fail rate is?
    if nothing is wrapped it will generate tons of heat. i wrap all the hot parts, the DP till it exits the motor. take whatever precaution i can to keep the heat out of the engine bay. even if it doesn't fix the problem it cannot hurt to take precatuionary measures.
    /twocents
    Quote Originally Posted by bgblockelcamino View Post
    X2. On my '95 with twins before the wrap, I could barely touch the OUTSIDE of the hood because it was so hot. After I wrapped the pipes, I could grab the exhaust pipe. It was some stuff I bought from Summit. DEI I think.
    Jan 2008
    Jefferson
    4,674
    ok maybe ill grab a turbo blanket and a 160* t-stat. Any brands I should look for on the turbo blanket??
    Darrin at rps and vs racing both have them.
    never stock biminiLX's Avatar
    Beaver
    2,406
    Before:
    After:
    Car obviously ran HOT without anything done, so I added a VS racing blanket, wrapped the DP with HEI large wrap and covered it with a reflective sheild as its under the water line, wrapped the headers with HEI 2" wrap (messy job but not hard), added the lower air dam, and had Scott Rod do a nice shrowd. Made a HUGE difference, I'd say you really need to wrap the headers, crossover and early DP before adding/changing parts.
    4V mod motors can be hard to purge but it sounds like you tried that.
    Good luck, turbos are great but they do run HOT.
    Jan 2008
    Jefferson
    4,674
    everytime I try to add a turbo blanket to "my cart" from VS racing it wont let me. anyone else having troubles!?
    Under PSI Black Vert's Avatar
    Cranberry Twp.
    344
    DEI makes a carbon fiber looking turbo blanket, looks cool, but cost a bit more than the VS Racing one. Both probably do just as good a job as the other. If you care about looks its an option. http://www.summitracing.com/parts/DEI-010144/
    89 Vert, Stock block, H/C/I , DIY turbo kit MPT70 , Tweecer RT, C4 trans. 17 lbs boost. 3400#s - 10.3 @ 136 mph.
    Dyno Jet - 542 RWHP / 545 RWTQ
    i recently had overheating issues myself. now granted Ive got a 4.6 with no force induction. I had the fan turn on about 20 degrees sooner than it originally would and it worked wonders for performance and overheating issues. but with you running that turbo like the others are saying it would defiantly have a major impact on the underhood heat in your car
    Jun 2007
    2,108
    I really haven't read this thread but also make sure the cooling system doesn't have air bubbles in it, these cars are notorious for it.
    Flat Bill Ron Ron89's Avatar
    Aug 2009
    43
    A really good guy I know just started selling some special coolant that I've heard a lot of good reviews about. He deals with custom turbo kits but it's mostly Subaru related.
    https://mooreperformanceparts.com/Hi...e_Coolant.html
    I can't personally review it because I have yet to use it but maybe it's worth a shot?
    State College, PA
    3,552
    i would get a 160* tstat since you are turbo and you said you saw coolant near the cap? try a new cap as well. and obviously the turbo blanket will prob help a lot but might not be necessary. do you still have stock rad?
    Beaver
    2,406
    Also, a higher than stock pressure cap can decrease overheating. My rad and AN lines can handle that, not sure about your stock stuff.
    Apr 2009
    134
    I'm assuming there's a bigass FMIC on there. In the past every FMIC I ran caused lots of cooling problems for me. It's never been so much underhood heat rather than airflow. Aside from the usual; I'd see if I could snake a slimfan infront of the radiator set to push.
    In the 8yrs of turbo cars; it's always been airflow that really stopped the problem..not ambient heat.
    VORTECH V3Si | INTERCOOLED | LONGTUBES | X PIPE | EIBACH | CORSA | MGW | SCT | LUND | 442/403
    Jan 2008
    Jefferson
    4,674
    thanks but problem solved last September mods please close..
  1. 91 Fox Briefly Overheating before normal temp
    By Zoom50 in forum Fox-SN95
    Last Post: 04-21-2014, 07:58 AM
  2. Overheating - some help please....
    By SonofaBish in forum General Tech
    Last Post: 08-19-2011, 01:01 AM
  3. Cobra is overheating! WTF!
    By Shadowstealth in forum SN95-New Edge
    Last Post: 06-02-2010, 10:46 PM
  4. 04 overheating
    By travj31 in forum General Tech
    Last Post: 05-03-2009, 11:53 PM
  5. Overheating
    By RUSH2112 in forum General Tech
    Last Post: 05-04-2007, 09:16 AM
