The car has 76,000 miles on it and is basically stock except for exhaust. It's a two barrel 302 with a 4-speed transmission. Only modifications are longtubes, o/r h-pipe, and flowmaster dumps. It's lowered about an 1" maybe a little more. It has a new cap, rotor, and plugs as well as new rear shocks and new front brake pads. The tires are fairly new as well. The underside is clean with no rust.
Being the car is 28 years old it does need a few things.
- Headliner (Have one from a hatch car but will need to cut for the t-tops)
- Driver's a-pillar trim
- Rear passenger trim piece is broken where a speaker was
- Carpet (Has grey in it currently)
- Driver's side rear seat brackets went through the floor courtesy of the previous owner weighing in at about 500 lbs (There is a solid steel plate under the seat now as the floor/studs will need to be welded)
- Paint
The car has various dents and dings in it with the main one being the driver's side fender (see pics). Any other questions just let me know.
I have a driver side front fender to go with the car and the car has 87 door panels in it, stock ones were junk.
also, front of hood has some small holes in it. not sure what they are from. previous owner painted it black, for what reason, i have no idea.
$2500
