Results 1 to 17 of 17
Thread: 347 or 408
    up and running
    Jun 2009
    south hills
    418
    347 or 408
    im looking to start a stroker build. whats the better route for a street car. im looking for 550-650 whp with the use of a blower. should i run the 347 or step up to a 408, what are you guys running. this build wont be for a while but like to see whats out there
    State College, PA
    3,552
    get a 351 block and take it to a 408....dont piss around if you can go bigger haha
    up and running
    Jun 2009
    south hills
    418
    I was leaning on 347 but at the same time a 408 or even a 427 with close to 20lbs of boost and a motor that can take it is sounding more enticing. Probably a little easier on the 408 rather than the 347
    A lot probably depends on budget and if you have things like the intake and other stuff that would need replaced going 351 based. I know a buddy had a lot more into those things than he expected when he went 351 based.
    South Hills, PA
    4,052
    make sure you get an aftermarket block, to make that kind of power you want you are looking well over 8k, or just put a BBC in it, cheaper
    More Power to Come! Stroked03Cobra's Avatar
    Kittanning/Butler
    1,055
    agreed... do not try to push a boosted 347 or even a 408 stock block. you will be running on limited time. I also have learned the hard way
    2003 Sonic Blue SVT Cobra - 711 RWHP @ 671 TQ @17psi. Kenne Bell 2.8, FRPP Modular Boss 5.0 block, Big Bore 324ci, with full stroker kit, JDM Stage 3 Heads, Custom Grind Cams and alot more. 4,900 original miles..... Currently at Street Lethal Performance for a makeover!
    1997 Mustang GT - 5 speed, 34k original miles
    1968 Fairlane GT - 302ci Hurst 4 Speed
    1999 Crown Vic - P71 Clone, JLT CAI, Dual 40 Series, Daily Driver
    You can easily make that kind of power with a 347, but to do it reliably you will need an aftermarket block as mentioned. Go 408 and you can make it much easier on yourself and the engine for that matter as you will not need as high of cylinder pressure to make the power due to the added cubes.
    Spencerport, NY
    3,762
    i agree with killer canary.... you want 550rwhp give or take... a 408 or 427 should be able to make close to that without any boost... i mean, if you use a real engine *ah hem* LSx *ah hem* ...... a 408/427 with 20psi will probably make like some gargantuous amoutn of power....
    e.g. .... my Trans Am made 698/706 on 11psi @ 11.0:1 a/f... current owner is making in the mid 900's rwhp on 16psi..... all this was on 348 c.i. LS1, with LS1 heads.... blower cars won't make as much power as a turbo car, but it won't be some rediculous amount less... only a small amount...
    2015 Corvette Z06
    - Shark Grey / Kalahari
    never stock biminiLX's Avatar
    Beaver
    2,406
    Price it out and I'm guessing you'll be happy and within a reasonable budget with a stock block 347 and boost to about 500rwhp.
    What are your goals with the car? street, track, combonation?
    What parts and blower do you have now?
    And I can tell you exactly what a 427 with 19psi can do ;)
    Well, at least on a dyno, it only took a touch under 14psi to trap 148mph a 3300# in 92* weather.
    I will also tell you its not cheap and WAY more power than you probably need :)
    up and running
    Jun 2009
    south hills
    418
    looking to do this over 2-3 years plan on spendidng close to 10k if not more. see alot of street duty with some track and a small amount if that. T trim now but was planning on starting with a fres h351 to stroke or even do a different block. want to run high teens to 20psi of boost
    Petersburg,PA. 16669
    816
    88 GT...and some boost
    Clean mineralrob's Avatar
    Pittsburgh
    1,994
    Quote Originally Posted by 349Stroker View Post
    wow hopefully things get sorted out out!!
    O.P. Good luck on the build!
    02 MG GT
    98 SVT Contour SF/MNB #2059
    93 Civic Hatch
    FAST WIT A FORD OVAL 90TitaniumStang's Avatar
    Feb 2009
    Latrobe
    517
    347 have a bad reputation for damaging gods and pistons because of how far the piston has to cmd out of the bottom Of the blocked I will have a 351w roller block already machined ready to sell in a couple weeks
    1989 GT Black,full 16 pt MOLY 8.50 CERT.
    461w Dart block w/ 4 bolt-all 5 caps
    EAGLE PENDULUM CUT ESP ARMORED 4.250
    PROBE PISTONS
    PROBE BILLET I BEAM
    super victor
    230cc CNC
    Hooker 2 in headers
    pa sc c4, 4600 stall
    9" LADDER 3.70 PRO GEARS
    SW BACKHALF
    moser 35 SPLINE axles
    1050 RACE DOMINATOR DEMON
    250 FOGGER KIT
    snow performance stage 2
    1.316 60ft 9.16@156
    up and running
    Jun 2009
    south hills
    418
    keep me posted on that. sorry i havnt got back to you on cam im away at school. but i think that cam is a little much for what id like to do. when you go to sell the block let me know. thanks for all the info
    Big member venom's Avatar
    North Fayette Township, PA
    1,344
    2015 GTPP
    South Hills, PA
    4,052
    Quote Originally Posted by venom View Post
    x2!!!!!!!!
    Beaver
    2,406
    I maybe selling my top-end (heads/intake/rockers). It won't be cheap but with it or any good flowing combo on a stock block 392-408 and your T-trim you'll have 9 second power.
  1. 85 fox suspension recomendations for a 408 stroker
    By tjvantana in forum Drag Racing
    Last Post: 04-20-2013, 01:55 PM
  2. 408 Thunderbird
    By Maxpowers in forum Pictures & Videos
    Last Post: 09-18-2012, 04:40 AM
  3. 408 Stroker
    By HidalgoGT in forum Ford Vehicles
    Last Post: 03-17-2009, 12:47 PM
  4. 1989 mustang 408 stroker
    By howardr8952 in forum Ford Vehicles
    Last Post: 08-29-2008, 07:41 PM
  5. 11.5cr Eagle 408 Trex
    By George C in forum Pictures & Videos
    Last Post: 07-18-2007, 05:15 PM
