Results 1 to 1 of 1
Thread: 1986 Mustang GT, no engine, selling entire hobby
    Uniontown, PA
    135
    1986 Ford Mustang GT - Drag setup but still street legal and driven
    Ran 10.3 @ 139 (with 408 and vortech supercharger)
    Have all documents, timeslips and most receipts
    No Engine
    Clear title (owned car since 98')
    All items below professionally installed and taken care of.
    Selling due to losing job and moving.
    Custom checkered Blue and pearl paint job
    fiberglass lift off hood
    ASP 7" Overdrive 8 rib one-piece crank pulley w/4" underdrive accessories and 3.33" SC pulley
    Vortech high volume Aluminum Discharge Tube with Mondo bypass
    K&N 9" Air Filter
    Morpheus 4" Power Pipe
    TKO 500 transmission - 26 spline input
    bellhousing setup for 351W
    RAM HD Powergrip clutch
    351 pressure plate (SFI approved)
    351 Damper (SFI approved)
    Aluminum driveshaft (mated output shaft for TKO 500)
    Aluminum clutch quadrant - fast release
    Steeda Adjustable clutch cable
    AEM standalone computer for Mustang - fully programmed and setup for Speed Density w/GM MAP sensor
    GM LQ9 wasted Spark ignition system (8 coil on plugs)
    high volume intake pump(Walbro GSS340 HiPressure 255LPH Fuel Pump) , inline high volume pump, 1/2" braided fuel lines, 5/8 fuel rails, Areomotive FPR
    Snow Performance Methanol injection system, boost controller, multiple jets
    Compucar Dry Nitrous system, purge, Numerous jets
    solid motor mounts
    polyurethane Transmission mount
    polyurethane cross member mounts
    polyurethane power steering mounts (offset)
    Trick Flow Tall Valve Covers
    1.6 Stud Mount 7/16" Roller Rockers by Summit Racing (15 - one broken)
    75mm Throttle body and 75mm EGR plate
    FMS Aluminum Driveshaft
    FMS Mini-Starter
    UPR Smog Pump Eliminator Pulley
    93 Cobra Overdrive WaterPump Pulley
    ASP/FORD Underdrive power steering pump pulley
    3G 130AMP alternator
    AutoMeter 5" Monster Tach with shift light
    Autometer 2 5/8 Water temp
    Autometer 2 5/8 Oil Pressure
    Autometer 2 5/8 Volt
    Digital boost gage with memory
    2 1/8 Fuel pressure gage
    2 1/8 Vac/Boost
    1 3/4" Full length 351W long tube headers with 3" ball and socket collectors
    Custom 3" exhaust
    3" 1 chamber Flowmaster mufflers with dumps
    Wide Band O2 sensor - setup with AEM
    5 bolt axles/drums
    5 bolt 11" slotted rotors with green stuff pads
    UPR chromoly K-member, A-arms, coilovers w/ 14"-130 springs
    UPR bumpsteer kit
    UPR chromoly solid upper and lower controls arms
    UPR rear anti-rollbar
    upper and lower battle boxes (welded)
    Steeda full length sub-frame connectors
    Weld draglite rims (front 15x6 - 225/50/15, rear 15x8 - 265/50/15 tires)
    Mickey Thompson ET Street 26X11.5X15 Tires
    Draglite 15X10
    Strange 10 way adjustable shocks and struts
    Global West Caster/Camber Plates
    S&W 8 Point Roll Cage
    RJS 5 Point Seat Belts (2)
    Taylor Aluminum Battery Box mounted in the hatch – above RR tire
    Taylor 150AMP cutoff switch
    Completely built 8.8 rear end
    3.73 gears
    Stange bullet end caps
    aluminum diff cover
    welded axle tubes
    33 spline Moser axles
    5/8 studs
    9" bearings (welded on) [c clip eliminators]
    lightweight spool
    140 MPH speedometer
    Autometer Electric Fuel Pressure Gauge
    Autometer Boost Gauge
    A-Pillar dual Gauge Pod
    Harwood Pin-on 2.5" Cowl Induction Hood
    Aluminum front and rear bumpers
    Plastic headlights
    SVO Leather Shift Knob
    7 quart canfield oil pan w/supercharger drain port
    Sony CDX-MP30 mp3 head unit
    Sony Speakers 5 ¼ Front, 6X9 Rear
    Removed Rear Seat, Carpet Insulation, Front Sway Bar and sway bar mounts, Dogbone, Wipers, Washer tank, heater core, heater hoses
    I am selling all parts and items related to this hobby. I have many bins of related parts and previously removed, such as:
    wiper motor, seat belts, springs, etc
    $7000
    can take Visa/MC via Paypal.
    Location Uniontown PA 15401
    derekbellotti@atlanticbb.net
    1986 Mustang GT, 408, Vortech Si-Trim, TFS 205CNC, 373s, TKO500, AEM, 10.3@139
  1. Selling 06 Mustang
    By 412mustangz in forum Ford Vehicles
    Last Post: 11-29-2013, 11:39 PM
  2. selling my 1999 v6 mustang
    By k7cobra in forum Ford Vehicles
    Last Post: 02-18-2012, 10:22 PM
  3. Selling My 1986 GT
    By Shorty429 in forum The Bar
    Last Post: 08-26-2010, 02:25 PM
  4. 2007 Mustang GT selling quick.
    By 07Alloy in forum Ford Vehicles
    Last Post: 03-21-2010, 09:06 PM
  5. Little hobby of mine
    By John4cam in forum The Bar
    Last Post: 02-11-2010, 12:17 PM
