Results 1 to 20 of 35
Thread: spring spacer to level sagging fox's
    Farmington WV
    4,672
    anyone used one of these? i heard a lot about them on MW and corral. my GT sits a little lower on the driver side rear and i heard this is common. a company (i forget who and where) makes 3 different size spacers depending on your sag. $30 each.
    i was going to order one when i get home....but thought id ask if anyone else has dealt with this.
    I was just noticing mine looks the same way. Guess it's just "Ready to Launch!" and transfer the weight to the right rear. :D
    Farmington WV
    4,672
    yea its something to do with the body and weight or something.....once i fond the link ill post it. the spacer changes nothing but ride height.
    Farmington WV
    4,672
    found it. Global West
    Rear spring perch spacers for leveling your cars ride height.
    You may have noticed some Mustangs from 1979-93 have a
    lower ride height on the divers side rear. Not to worry, we have
    a simple fix. We use a special rear coil spring spacer machined out of
    billet. This will not change anything but the ride height. The
    spring spacer goes under the coil spring and indexes on the control
    arm. The spacer will also re-index the coil spring.
    Spacers will also fit 1994-05 models.
    We make 3 different height spacers.
    Part# 1100 = 5/8 inch change
    Part# 1101 = 3/4 inch change
    Part# 1102 = 7/8 inch change
    (Only one spacer needed per car) Price 28.59
    ea.
    http://www.globalwest.net/mustang%20...erch%20spacers
    You may want to put you new springs on 1st before ordering anything. The rear's are easy enough to get back out if you have to add one.
    My car sat even when I had the lowering springs on it.
    Farmington WV
    4,672
    hmmmm...yea i know the rears are easiest....i just figured in doing it right the first time.
    Well, you would 1st have to see how much of a spacer you would need before you ordered it anyways.
    Farmington WV
    4,672
    thought i posted that here...i have roughly 1/2" difference.
    But that's with the "Stock" springs. You have NO IDEA what the difference, if any with the new springs will be!
  1. Stock Fox front spring install
    By JOlbert in forum Fox-SN95
    Last Post: 11-12-2012, 05:33 AM
  2. Fox rear spring question (w pic)
    By Floyd in forum Fox-SN95
    Last Post: 09-06-2012, 05:54 PM
  3. Fox Upper spring mounts
    By Floyd in forum Ford Parts
    Last Post: 08-21-2012, 12:12 AM
  4. FS: 4 CYL Fox spring set, clean, not rusty crap
    Last Post: 06-17-2011, 01:32 PM
  5. fox body spring question
    By PSPstang in forum Fox-SN95
    Last Post: 10-31-2007, 07:52 PM
