Results 1 to 6 of 6
Thread: 5.0 swap
    May 2009
    Leetsdale
    226
    5.0 swap
    My friend just bought a 93 lx 4 cyl. with an automatic transmission. He wants to know what all he would need to convert it to a 5.0 302. Any advice is appreciated.
    2013 Ford F-150 XLT
    2004 GT- Bolt ons - SOLD
    Leetsdale Fire Department- Station 309
    out in the woods
    4,948
    is he doing carb'd or EFI?
    May 2009
    Leetsdale
    226
    He plans on doing EFI
    2013 Ford F-150 XLT
    Quote Originally Posted by 40thGT View Post
    Unbolt anything that's 2.3 and A4LD and bolt in all the new parts :D
    In most cases, you are miles (and $$$'s) ahead to just find a V8 car to start. Especially if you don't have the donor car or have to ask how it's done. Just my measly .02.
    This is especailly true as you move to the newer (as in 93) cars with air bags and so much tied into the same wiring harness. The later 2.3 cars rerally added alot with dual plugs and DIS. Effectively you end up swapping the engine, trans, wiring harness, then need to swap rears and brakes. All you keep is the chassis.
    May 2009
    Leetsdale
    226
    What would you estimate the cost at for a complete swap?
    2013 Ford F-150 XLT
    out in the woods
    4,948
    it would be so much easier to find a wrecked donor 5liter. since the car is a 93,he will have to stay with 91-93 wiring harness.
    motor
    tranny
    fuel lines
    crossmember
    rearend (can run the 7.5 but 8.8 will hold up much better on v8's)
    driveshaft
    computer
    wiring
    exaust
    fuel pump
    spindals (4cyl front suspension works but 8cyl stuff holds better imo)
    springs (same as above stated)
    so much easier to find on thats wrecked so he's not puttin a car together off parts from here-there cars...
  1. 5.4 swap
    Last Post: 10-15-2012, 05:33 PM
  2. PI Swap
    Last Post: 02-21-2011, 02:39 PM
  3. 4.0 swap?
    By sweeney1030 in forum General Tech
    Last Post: 01-07-2009, 08:40 PM
  4. v6 t-5 swap
    By 97LaserRed in forum Ford Parts
    Last Post: 08-07-2008, 12:43 AM
  5. 4v swap
    By LXguy88 in forum S197
    Last Post: 05-19-2008, 12:08 AM
