Results 1 to 2 of 2
Thread: Lowering springs problem...Help
    Junior Member DG27's Avatar
    Sep 2010
    New Castle,PA
    5
    On my 89 GT it has Eibach springs part #'s 3510.301 Front and 3510.302 Rear. The left side of my car sits about 2.5 inches lower than the right side. On the rears the end of each spring pigtail is pointing to the drivers side. The front feel like they are in the pockets but not 100% sure. Any suggestions? Can these springs just be tossed in or do they need to seat in a certain position? BTW Iposted this on Stangnet too...
    1989 GT
    STOCK 302
    FLOWMASTERS
    O/R H PIPE
    Mar 2009
    796
    This is just a possible guess....
    Did you remove or replace any control arm/bushings? If so you need to have the car's
    weight loaded on the control arms (using your jack) before tightening the bolts. If you
    just let them hang and tighten the bolts the bushings will have pre load. In your case
    it could be the corners that are higher than the others.
  1. Wanted - stock springs or lowering springs for 95 gt
    By Whats_Missing? in forum Ford Parts
    Last Post: 11-15-2012, 10:27 PM
  2. Lowering Springs..
    By pRojekt02GT in forum General Tech
    Last Post: 05-31-2009, 03:17 PM
  3. Lowering Springs
    Last Post: 01-20-2008, 12:13 PM
  4. 99-04 Lowering Springs
    By da9k1ne in forum Ford Parts
    Last Post: 12-24-2007, 03:36 PM
  5. lowering springs ford racing c springs like new
    By silverworm in forum Ford Vehicles
    Last Post: 10-22-2007, 03:38 PM
