Hey guys up for sale is my mustang.
1995 mustang former v6 car
Lentech built aod
Just gone thru by Abruzzi racing transmissions
Forged pistons,
eagle stroker crank,
Eagle rods,
comp link bar solid roller lifters,
custom turbo cam by Jay Allen @ camshaft innovations.
dur @ .050 int 237 ex 243
gross lift int .625 ex .609
lobe separation 114
Trick flow track heat intake upper and lower
harland sharp rockers specific to vic jr heads
k motion springs
Vic jr heads
Trick flow pushrods
Professional products rails and regulator
BBK throttle body 75mm and egr spacer
Ford racing tall valve covers (hammertone powder coated)
March accesory brackets
Canton 7 qt pan and pickup
modified boost brothers turbo kit
76mm turbonetics turbo
60lb siemens deka injectors
car is ran on a ford racing harness with an a9l
sct big air 3000 meter and chip custom dyno tuned.
built 8.8 with 3.55 gears
31 spline moser axles
31 spline ford hd trac lock
umi adjustable rear suspension
lakewood 90-10 front struts
Maximum motorsports solid engine mounts
new mickey thompson 275 drag radials
centerline tel star wheels
Crane Hi-6 ignition box and msd coil.
Fluidyne radiator and derale fan
has race bullet mufflers now but have some 3 inch chambered ones to install either way
Glenns sleeper sump tank with twin 255lph pumps
-8 feed and -6 return
Made 555 rwhp and 580 torque with the 4.10 gears installed and slicks on it. Timing was no where near maxxed out
It is 10.2.1 compression
Does have a turbonetics manual boost controller.
B&M shifter
It has boost,water temp,oil pressure, and tach gauges.
Pretty sure I left some stuff out.
During the install of the transmission I had an accident and lost a portion of my finger. I need the money to pay medical exspenses etc.
I'm asking 8,000.
Car made 555 rwhp by accident.
Body is not perfect but solid.
