Results 1 to 20 of 29
Thread: 1991 Fox with kenne bell blower supercharger
    Senior Member oldfox's Avatar
    May 2009
    296
    Hey everyone this car is no longer available
    Thanks Lee
    I'm going to sell my fox I have been driving it for years and it's been a great car. The interior is pretty much spotless a lot of it has been replaced.
    The outside has some chips in the paint and front bumper but no rust.
    It has a 2.1 Kenne bell blower I have the biggest pulley you can run it only puts out 5-6 lb boost but I have some smaller pulleys that will bring it up to 7-10 and one that is even higher.
    The blower head unit is a 2010 model it's about 6mo old
    Has adjustable MSD BTM for the timing
    5-lug with disc brakes front and rear.
    8.8 rear end with 3:55 gears- speedometer reads correct.
    stock am-fm cassette with a 10 disc changer in the back
    wheels are off of a 2009
    Big aluminum radiator
    cobra rear bumper cobra R hood w/scoops
    Has cruise control and air conditioning--works
    windows and locks work.
    non smoker ash tray lid works
    has a 4 point roll bar works out nice the back seats still fold down
    and it's out of the way you can still get in and out of the back.
    engine is a 302 board 30 over (306) 8.5 to one about 20,000 mi
    Just lots of stuff Just call if you like to get more information
    304-478-4430 Lee for map quest use zip 26287
    I'm usually home in the evenings after 8:00 pm no calls after 11. The price is $5,500 I have never seen a fox in this nice of shape for that price. with or without a supercharger. --That is the price I'm firm an offer for less will be seen as an insult
    May 2009
    296
    May 2009
    296
    May 2009
    296
    May 2009
    296
    I have been using this car as a daily driver I drive it to Ohio and back about 2-3 a month. (500 mi round trip) this summer I drove it to Tampa Fla. On vacation
    20 to 24 mpg is what I get depending on how I'm driving
    True mileage is unknown the speedometer was replaced before I got the car
    and I replaced once myself (140 mph)
    May 2009
    296
    309
    any rust underneath? rust at strut area underneath? clean title?
    May 2009
    296
    It's a Fla car it's clean underneath. No rust
    Mar 2009
    796
    Does car have a sunroof? Does all accessories / AC work?
    Any noises or issues with the clutch, trans, or diff?
    Is the steering / suspension tight?
    Member madmaxin22's Avatar
    on the red belt
    853
    is this a 4 cyl conversion or a 5.0 original car?
    2014 RAM QUAD CAB 8SPD
    May 2009
    296
    this car is a conversion car. It started out as a 4cylinder lx
    It has a sun roof A/C and other stuff works- just like it says above
    It was converted this spring to a V-8 it was done correctly never had any problem with it- has new V-8 springs also -- The front spindles and breaks are off of a 94
    I have a picture of the undercarriage taken last year-- It's dirty underneath now but it gives you a good look at the set up --Not the same exhaust it now has 2 1/2 flowmaster set up with a "x" pipe no converters It was a 4cylinder when this was taken--
    Also has a new aluminum drive shaft now. If you look you can see the frame rails are tied
    May 2009
    296
    Gibsonia
    772
    A/c still R12 or R134a?
    My collection:
    01 cobra in pieces
    02 dodge cummins
    309
    what area do you live in
    Quote Originally Posted by tjvantana View Post
    1969 Camaro restomod/project
    1967 camaro
    2011 mustang procharged
    93 reef blue notch blk/int
    92 calypso notch blk/int
    86 t-type
    1972 chevelle project
    May 2009
    296
    uses 134a I had a new compressor and lines installed over the summer and it was converted at that time. Blows cold
    309
    does the kenne bell fit a gt40 lower or stock 5.0 lower?
    How many miles are on the car?
    Wow - looks like a great car for the money - I'm shocked it is still available - good luck with the sale!!
    I'll pass the info along to a friend of mine.
    Why don't you post a picture on here so we can see what she looks like.
  1. Ford Escape Kenne Bell Supercharger
    By SK@StreetLethal in forum Ford Vehicles
    Last Post: 02-17-2019, 08:32 PM
  2. gt 500 supercharger whipple vs kenne bell
    By PSPstang in forum S197
    Last Post: 06-23-2012, 09:25 AM
  3. Kenne Bell supercharger for 86-93 Fox Mustang
    By oldfox in forum Ford Vehicles
    Last Post: 06-27-2011, 10:44 AM
  4. Replies: 5
    Last Post: 06-14-2008, 09:57 AM
  5. For Sale: 07 - 08 Shelby 5.4 Kenne Bell 2.8 H supercharger
    Last Post: 06-02-2008, 12:13 AM
