Results 1 to 1 of 1
Thread: Saleen Watts Link
    Saleen Watts Link
    Used for only 500 miles.
    The add says it fits 2005 - 2007 mustangs, but im sure it fits at least up to 2009 models. Here is the write-up on it:
    The Watts-link was made famous in the classic Parnelli Jones 302, but Saleen modernized it for the Saleen/Parnelli Jones Limited Edition. The Saleen-Link system replaces the factory live-axle set-up with a reinforced rear differential cover, billet-aluminum pivot, steel link arms. Improves the handling dynamics of the car by giving the live axle a true live-center. This allows the axle to pivot through the center of the differential and move up and down without the tires scrubbing side to side. This keeps the tires flat to the ground, enhancing grip and control. Expect an improvement of corner speeds and quicker lap times.
    There was a recall on the first revision of this setup. The one I have is the latest revision with all of the fixes in place.
    $550
  1. CL link to 89gt partout
    By INSANELY CRAZY in forum Ford Vehicles
    Last Post: 02-18-2010, 06:11 PM
  2. Link to some WoW shots
    By CobraII in forum Meets & Events
    Last Post: 02-23-2008, 12:07 PM
  3. 89 notch link inside
    Last Post: 11-04-2007, 04:18 PM
  4. LMM - i can link them right LOU
    By J-rod in forum The Bar
    Last Post: 02-08-2007, 10:59 AM
  5. toe link bars
    Last Post: 02-01-2007, 11:46 AM
