Results 1 to 6 of 6
Thread: Ford Edge
    Ford Edge
    Can someone help me out with any type of instructions on how to remove the rear rotors from a 2007 Ford Edge. I have a idea on how, but the old saying " Try before you pry" comes to mind. Any help would be greatly appreciated.
    PJ
    2003 Mineral Grey Cobra
    2014 Harley Davidson Street Glide
    www.mystation200.com
    Sep 2008
    555
    Don't they just pop off after removing the caliper bracket? I'd say a 15mm to get the caliper brackets off, then if the rotor doesn't slip off a little sledgehammer persuasion should help out.
    Live free or die
    Senior Member ttk53's Avatar
    Sep 2008
    369
    you make sure the ebrake is off. sometimes its something dumb.
    When I looked to take them off, there is a hole in the front of the rotor just like the Chevy Trackers had. On them, you had to thread a bolt in to take them off.
    When I went to take them off, I figured they would be like my F-150 but they are different. I just don't want to break anything.
    PJ
    The BOSS GOT SVT's Avatar
    Cranberry Twp PA
    3,045
    call marc
    Current Stable
    1993 Red Cobra
    Previous Stable
    2012 White Mustang-Traded
    2003 Black Cobra-Traded
    1998 Black Cobra-Traded
    1991 White 5.0 Conv-Sold
    Under PSI Black Vert's Avatar
    Cranberry Twp.
    344
    Take the rubber plug out of the rotor, turn the hole to the top where the e-brake adjuster is and use a screwdriver to back the adjuster up to loosen the shoes. The rotor then should slide off if its not to rusted up, if it is you just have to pry on it.
  1. 2011 Ford Edge limited wheels
    By jaa55 in forum Ford Parts
    Last Post: 11-30-2014, 09:38 PM
  2. edge
    By GOT SVT in forum The Bar
    Last Post: 12-30-2013, 03:49 PM
  3. Ford Mustang AOD Edge Racing torque converter
    By roush08 in forum Ford Vehicles
    Last Post: 02-16-2011, 05:36 PM
  4. New Edge + Fox = ?
    By 95riosnake in forum Pictures & Videos
    Last Post: 03-30-2010, 09:34 PM
  5. Ford Edge
    By molnartr in forum The Bar
    Last Post: 07-20-2008, 11:43 PM
