Thread: Bleeding the AC system
    Cheap SOB
    Baltimore, Maryland 21236
    288
    Evacuating the AC system
    I am prepping my car for paint and I pulled the engine. I got a little carried away and have pulled most of everything out. All that is left is the power steering / brake booster and master cylinder / AC components. I am about to go out and pull the brakes and power steering pump. That leaves the AC parts. How do I recover the Freon (R-12)? If I have to discharge the system without a recovery system, I don’t see how that can be done safely for me or the environment.
    Just let it bleed into the air and get the fittings to convert it to R-134a when you put it back on. Just remember to pump the lines down with a vacum pump before recharging the system.
    You will have to pump the lines down at least twice to get all of the air and moisture out with the vacum pump. You'll know you've done it enough when it stops loosing vacum.
    Cheap SOB
    288
    I have read warning about frostbite. Is this a real problem? It a rapidity discharge the system how to I get the compressor oil back into the system? I thought the Compressor oil for R12 (mineral oil (5GS)?) is not compatible with the R132a oil (PAG?)?
    Quote Originally Posted by DRRummel View Post
    If you just crack the line open and let it bleed out, frostbite will not be an issue. This is assuming you don't hold your hand there after you do it!
    Not sure on the oil question. I had a buddy that did automotive A/C work convert mine over. The connectors were the only thing I noticed different afterwards. I have since removed everything from the car, so I never had to recharge it.
    3,499
    Just let it bleed into the air .
    Ozone slayer
    Ozone slayer
    Member loutheplumbr's Avatar
    Mc Donald PA
    80
    try to find R-414b aka Hot Shot by icor it runs a very simular pressure and tempatures as R-12 plus there is no oil compatibilty problems
    1985 Mercury Capri
    2.3 Turbo T-5
    1988 Ford Thunderbird Turbocoupe losing its powertrain
    1993 lx vert getting re-powered
    1959 Ford 871 undergoing operational restoration
    2011 Dodge Ram 2500 HD Cummins
    1984 Ford E350 Tow Vehicle Project 7.5L
  1. JL Audio system
    By 02torchgtslp in forum For Sale
    Last Post: 01-07-2009, 06:26 PM
  2. Brake Bleeding??
    By Inkdcountryboy in forum SN95-New Edge
    Last Post: 07-05-2008, 01:14 PM
  3. Bleeding the Brakes..
    By MadMaxTalbot25 in forum General Tech
    Last Post: 05-22-2008, 04:30 PM
  4. My Eyes Are Bleeding!! Ahhhhhh!!!
    By phillysrt4 in forum The Bar
    Last Post: 12-13-2007, 10:22 PM
  5. Bleeding lifters???
    By 92306gt in forum General Tech
    Last Post: 11-17-2007, 09:00 PM
