for Forced Induction!
Dropped block off at DLK tuesday at lunch and was done by 3:15pm Just hottanked/degreased but man its clean. Now to deburr inside of block and tap oil drain backs for tubes to control oil return to pan. Order some studs for mains, heads and new bolts for side bolts. May use the rear seal plate from MMR since it's 1/2" thick Billet which should be stiffer than stock.
Got answer from DSS and pistons should be shipped tomorrow. They had to make them and pin fit them.
Things seem to coming along well Ed. I look forward to seeing the build.
So are you gonna by-pass 11's and go straight to tens? HAHAHA
Finally got my Pistons from DSS. Now to get some rods and maybe a crank.
purdy, think Wick is right :)
Any updates Ed?
wow nice slugs
Have set of Manley H-Beam rods resized to ultra tight specs on the way. Looking at a Kellog crank and 10%overdrive dampner
Been thinking of changing up my power adder. Seriously thinking of selling the Vortech setup and going turbo. Kinda one of those do I or don't I moments :)
Don't do it Ed. Believe me it pains me to try and steer you away from a turbo, but for the racing you do, stay with the belt drive SC and have fun. I know that is against every bit of my being, but you have seen what I go through trying to bracket race and its too many variables.
Just my .02 fwiw
Before I read Bob's response....my mind said...DON'T
Was thinking of the new ON3 setup using forward facing headers and a 70 or 76mm turbo. Nice kits for the money even if not perfect. Lil tweaking to them. Maybe something to try if I use the DOHC heads on my iron block and shove it in the GT350
Got nice deal on forged crank. So should have that this week.
laserred has on on3 kit for sale
Cool build, I think I would go turbo but if you bracket race alot it could be a pain but it would be fun regardless. Keep up with the good work, look forward to seeing more posts.
working on the shelby
Got the crank today. So now just need to decide on bearings and rings and get it all checked to see what if any change to balance needs done.
Crank
Rods
