Page 9 of 23 FirstFirst ... 789101119 ... LastLast
Results 161 to 180 of 444
  1. #161
    Spent day cleaning up my mess of random wires from out under dash. Got dash pulled. Ended up being easier than I expected. Pulled heater box weighed it. It was 18lbs gone. Friggn dash is heavier than it looks. Will see what I can remove from that. Get the holes in firewall closed up an engine bay will be done.
    Also weighed stock driver seat and must say it weighed more than I thought. 60lbs
    Already have most of the rubber/foam off firewall which is not shown removed. Just have more to get off around pedal assembly. Guessing 5lbs there but will know once weighed.
  2. #162
    Jul 2011
    Meyersdale, PA
    1,101
    Was you stock seat a power seat? I was gonna swap to a manual seat base in my Mach 1 because I think you can get the seat to go into a little lower position and I'm guessing it would save a good bit of weight.
  3. #163
    Yes, power/leather.
  4. #164
    Patiently waiting to see if he removes third pedal "to save weight" ....
  5. #165
    When hell freezes over
    Got all that rubber/foam off firewall. 7lbs
  6. #166
    When hell freezes over s
    just checking if we needed an intervention (beating you relentlessly with a torque converter and covering your wounds with ATF)
  7. #167
    Got holes from heater box closed up. Just need some light touch up and sanding and I can paint engine bay.
  8. #168
    looking good
  9. #169
    You ought to trim that pinch weld down on the firewall. Go back to the spot welds. It can take an easy inch off and looks so much better too.
  10. #170
    I've seen that and it does look good. Might do that. Should be a quick clean job. Course with my luck it will take more time than I thought. Like everything else I've done so far
  11. #171
    Hahaha. Yeah. I know the exact feeling.
    Honestly, when I did mine I think it took 3 minutes. 4" grinder with a cut wheel, then a flapper disc to debur it.
  12. #172
    As a bonus. You lose about a pound of steel too! Haha.
  13. #173
    it's soo-tack sutyak's Avatar
    Fairmont, WV
    2,467
    Looking great!
  14. #174
    Think it came out ok. I didn't trim pinch weld back.
  15. #175
    Polar Vortex
    6,031
    Looking good!
  16. #176
    charleroi
    478
    Nice work!
  17. #177
    Looks nice Ed.
    Now, start filling it back in!!
  18. #178
    Is it go time yet?
  19. #179
    Senior Member Dan B.'s Avatar
    Armagh, PA
    4,331
    Racecar stuff right there.
    Ahh fuque
    1986 Ranger--2WD, 5.0/T5/8.8.
  20. #180
    Looks nice Ed.
    Need oil pan, header gaskets, header bolts. Then can drop motor back in. Then the fun of modifying the chassis/engine harnesses begins.
    Last Post: 01-25-2013, 11:32 AM
  2. wtb: Teksid block
    Last Post: 12-03-2012, 09:45 AM
  3. 96 Teksid lincoln motor
    Last Post: 04-06-2010, 04:30 PM
  4. WTB teksid block
    By scott5 in forum Ford Parts
    Last Post: 12-12-2009, 08:31 AM
  5. F/S Teksid Block
    Last Post: 07-19-2009, 10:10 PM
